[petsc-dev] PETSc-3.13.0/Sundials
    Satish Balay
    balay at mcs.anl.gov
    Sat Apr  4 10:36:38 CDT 2020
I believe Sundials-5 API has changed considerably wrt version 2.5 that this would need considerable rework. And currently there are no takers for this..
However Sudials has some code to call PETSc for some features..
Satish
On Sat, 4 Apr 2020, Jed Brown wrote:
> Hmm, it's uncharacteristic for this support to be so out of date, but I
> suspect it will not work at present.  You could try increasing this
> number and see what breaks.  We'd love a merge request to make that
> update, even just a start until there is a problem you don't know how to
> fix.
> Antonio Trande <anto.trande at gmail.com> writes:
> > Hi all.
> > Can anyone tell me if PETSc-3.13.0 and Sundials-5* are compatible?
> > That's, is it possible compiling petsc with recent Sundials releases by
> > using the options:
> >   --with-sundials=1
> >   --with-sundials-include=/usr/include/openmpi
> >   --with-sundials-lib=-lsundials_nvecparallel
> > The file `petsc-3.13.0/config/BuildSystem/config/packages/sundials.py`
> > reports:
> >     self.version      = '2.5.0'
> >     self.maxversion   = '2.5.100000'
> > so, i presume, it doesn't.
> > Antonio Trande
> > Fedora Project
> > mailto 'sagitter at fedoraproject dot org'
> > GPG key: 0x7B30EE04E576AA84
> > GPG key server: https://keys.openpgp.org/
