[petsc-dev] PETSc-3.13.0/Sundials
    Antonio Trande
    anto.trande at gmail.com
    Sat Apr  4 09:49:34 CDT 2020
On 04/04/20 15:29, Jed Brown wrote:
> Hmm, it's uncharacteristic for this support to be so out of date, but I
> suspect it will not work at present.  You could try increasing this
> number and see what breaks.  We'd love a merge request to make that
> update, even just a start until there is a problem you don't know how to
> fix.
Sundials libraries are not recognized.
See the config.log attached, please.
> Antonio Trande <anto.trande at gmail.com> writes:
>> Hi all.
>> Can anyone tell me if PETSc-3.13.0 and Sundials-5* are compatible?
>> That's, is it possible compiling petsc with recent Sundials releases by
>> using the options:
>>   --with-sundials=1
>>   --with-sundials-include=/usr/include/openmpi
>>   --with-sundials-lib=-lsundials_nvecparallel
>> The file `petsc-3.13.0/config/BuildSystem/config/packages/sundials.py`
>> reports:
>>     self.version      = '2.5.0'
>>     self.maxversion   = '2.5.100000'
>> so, i presume, it doesn't.
>> Antonio Trande
>> Fedora Project
>> mailto 'sagitter at fedoraproject dot org'
>> GPG key: 0x7B30EE04E576AA84
>> GPG key server: https://keys.openpgp.org/
Antonio Trande
Fedora Project
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200404/d4af73e3/attachment-0001.zip>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20200404/d4af73e3/attachment-0001.sig>
