[petsc-dev] PETSc-3.13.0/Sundials
Jed Brown jed at jedbrown.org
Sat Apr 4 08:29:32 CDT 2020
Hmm, it's uncharacteristic for this support to be so out of date, but I
suspect it will not work at present.  You could try increasing this
number and see what breaks.  We'd love a merge request to make that
update, even just a start until there is a problem you don't know how to
fix.
Antonio Trande <anto.trande at gmail.com> writes:
> Hi all.
> Can anyone tell me if PETSc-3.13.0 and Sundials-5* are compatible?
> That's, is it possible compiling petsc with recent Sundials releases by
> using the options:
>   --with-sundials=1
>   --with-sundials-include=/usr/include/openmpi
>   --with-sundials-lib=-lsundials_nvecparallel
> The file `petsc-3.13.0/config/BuildSystem/config/packages/sundials.py`
> reports:
>     self.version      = '2.5.0'
>     self.maxversion   = '2.5.100000'
> so, i presume, it doesn't.
> Antonio Trande
> Fedora Project
> mailto 'sagitter at fedoraproject dot org'
> GPG key: 0x7B30EE04E576AA84
> GPG key server: https://keys.openpgp.org/
