[petsc-dev] TAP file and testing error
Scott Kruger kruger at txcorp.com
Thu Sep 26 10:18:41 CDT 2019
On 9/26/19 12:45 AM, Stefano Zampini wrote:
> You usually get the backslash when you trying to be quick and
> tab-complete the command :-)
Yes, I agree that the makefile should fix this.
> and, so far, PETSc accepted this. We should either filter the variable
> in the makefile, or change the filenames with their paths.
> Scott, are the two PETSC_ARCH specifications really needed in the
> filename? I mean first as a folder, than in the filename itself
Barry or Satish should confirm, but as I recall the idea is that if you
are collecting the the log files into a dashboard, then the PETSC_ARCH
labeling scheme is best.
Pierre Jolivet has an bug report in, and I have the show-test
functionality in, so I'll try to get a new MR out soon.
Scott
> Il giorno gio 26 set 2019 alle ore 09:38 Matthew Knepley
> <knepley at gmail.com <mailto:knepley at gmail.com>> ha scritto:
>     On Wed, Sep 25, 2019 at 8:52 PM Stefano Zampini via petsc-dev
>     <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>         If we specify a PETSC_ARCH with a trailing slash, the current
>         testing makefile fails. Can this be fixed?
>     PETSC_ARCH is a string name and not necessarily a directory. I think
>     we should check and fail if it has a slash.
>         Matt
>         *zampins at vulture*:*~/Devel/petsc*$ make -f gmakefile.test test
>         globsearch="*densecuda*" PETSC_ARCH=arch-gpu-double-unifmem/
>         touch: cannot touch
>         './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_tap.log':
>         No such file or directory
>         touch: cannot touch
>         './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_err.log':
>         No such file or directory--
>         Stefano
>     What most experimenters take for granted before they begin their
>     experiments is infinitely more interesting than any results to which
>     their experiments lead.
>     -- Norbert Wiener
>     https://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
> Stefano
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
