[petsc-dev] TAP file and testing error
    Balay, Satish
    balay at mcs.anl.gov
    Thu Sep 26 10:28:37 CDT 2019
On Thu, 26 Sep 2019, Scott Kruger via petsc-dev wrote:
> On 9/26/19 12:45 AM, Stefano Zampini wrote:
> > You usually get the backslash when you trying to be quick and tab-complete
> > the command :-)
> Yes, I agree that the makefile should fix this.
> > and, so far, PETSc accepted this. We should either filter the variable in
> > the makefile, or change the filenames with their paths.
> > Scott, are the two PETSC_ARCH specifications really needed in the filename?
> > I mean first as a folder, than in the filename itself
> Barry or Satish should confirm, but as I recall the idea is that if you are
> collecting the the log files into a dashboard, then the PETSC_ARCH labeling
> scheme is best.
Well previously - for the dashboard - we did the rename during the copy [from build location to the dashboard].
If I remember correctly only one generated file had PETSC_ARCH encoded
- that is PETSC_ARCH/lib/petsc/config/reconfigure-PETSC_ARCH.py - so
that its easy to copy/save/reuse this script.
Its not clear to me what type of dashboard we can have in the future -
and how to get the logs there [beyond the current one at gitlab at
https://gitlab.com/petsc/petsc/pipelines]
Satish
> Pierre Jolivet has an bug report in, and I have the show-test functionality
> in, so I'll try to get a new MR out soon.
> Scott
> > Il giorno gio 26 set 2019 alle ore 09:38 Matthew Knepley <knepley at gmail.com
> > <mailto:knepley at gmail.com>> ha scritto:
> >     On Wed, Sep 25, 2019 at 8:52 PM Stefano Zampini via petsc-dev
> >     <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
> >         If we specify a PETSC_ARCH with a trailing slash, the current
> >         testing makefile fails. Can this be fixed?
> >     PETSC_ARCH is a string name and not necessarily a directory. I think
> >     we should check and fail if it has a slash.
> >         Matt
> >         *zampins at vulture*:*~/Devel/petsc*$ make -f gmakefile.test test
> >         globsearch="*densecuda*" PETSC_ARCH=arch-gpu-double-unifmem/
> >         touch: cannot touch
> >         './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_tap.log':
> >         No such file or directory
> >         touch: cannot touch
> >         './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_err.log':
> >         No such file or directory--
> >         Stefano
> >     What most experimenters take for granted before they begin their
> >     experiments is infinitely more interesting than any results to which
> >     their experiments lead.
> >     -- Norbert Wiener
> >     https://www.cse.buffalo.edu/~knepley/
> >     <http://www.cse.buffalo.edu/~knepley/>
> > Stefano
