[petsc-dev] TAP file and testing error
Stefano Zampini
stefano.zampini at gmail.com
Thu Sep 26 01:45:11 CDT 2019
You usually get the backslash when you trying to be quick and tab-complete
the command :-)
and, so far, PETSc accepted this. We should either filter the variable in
the makefile, or change the filenames with their paths.
Scott, are the two PETSC_ARCH specifications really needed in the filename?
I mean first as a folder, than in the filename itself
Il giorno gio 26 set 2019 alle ore 09:38 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Wed, Sep 25, 2019 at 8:52 PM Stefano Zampini via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> If we specify a PETSC_ARCH with a trailing slash, the current testing
>> makefile fails. Can this be fixed?
> PETSC_ARCH is a string name and not necessarily a directory. I think we
> should check and fail if it has a slash.
> Matt
>> *zampins at vulture*:*~/Devel/petsc*$ make -f gmakefile.test test
>> globsearch="*densecuda*" PETSC_ARCH=arch-gpu-double-unifmem/
>> touch: cannot touch
>> './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_tap.log':
>> No such file or directory
>> touch: cannot touch
>> './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_err.log':
>> No such file or directory--
>> Stefano
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190926/22eb5402/attachment-0001.html>
