[petsc-dev] TAP file and testing error
Matthew Knepley
knepley at gmail.com
Thu Sep 26 01:38:30 CDT 2019
On Wed, Sep 25, 2019 at 8:52 PM Stefano Zampini via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> If we specify a PETSC_ARCH with a trailing slash, the current testing
> makefile fails. Can this be fixed?
PETSC_ARCH is a string name and not necessarily a directory. I think we
should check and fail if it has a slash.
Matt
> *zampins at vulture*:*~/Devel/petsc*$ make -f gmakefile.test test
> globsearch="*densecuda*" PETSC_ARCH=arch-gpu-double-unifmem/
> touch: cannot touch
> './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_tap.log':
> No such file or directory
> touch: cannot touch
> './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_err.log':
> No such file or directory--
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190926/50c01cb1/attachment.html>
