[petsc-dev] TAP file and testing error
Scott Kruger
kruger at txcorp.com
Wed Sep 25 17:33:17 CDT 2019
Can you try rerunning after removing the trailing backslash to PETSC_ARCH?
Scott
On 9/25/19 1:51 PM, Stefano Zampini wrote:
> If we specify a PETSC_ARCH with a trailing slash, the current testing
> makefile fails. Can this be fixed?
> *zampins at vulture*:*~/Devel/petsc*$ make -f gmakefile.test test
> globsearch="*densecuda*" PETSC_ARCH=arch-gpu-double-unifmem/
> touch: cannot touch
> './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_tap.log': No
> such file or directory
> touch: cannot touch
> './arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_err.log': No
> such file or directory--
> Stefano
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
