[petsc-dev] error with karlrupp/fix-cuda-streams
    Mark Adams
    mfadams at lbl.gov
    Wed Sep 25 21:16:21 CDT 2019
OK, I deleted the arch directory and stared over and it seems to be correct:
#define PETSC_VERSION_BRANCH_GIT "(detached from
origin/balay/fix-mpiexec-shell-escape)"
#define PETSC_VERSION_DATE_GIT "2019-09-25 15:53:38 -0500"
#define PETSC_VERSION_GIT "v3.11.3-2242-gcb53a04"
I have a kind of complicated workflow here so I might have dropped
something earlier but I verified that this file has this correct version.
On Wed, Sep 25, 2019 at 8:43 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> This log is from the wrong build. It says:
>             Defined "VERSION_GIT" to ""v3.11.3-2242-gb5e99a5""
> i.e its not with commit cb53a04
> Satish
> On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> > Here is the log.
> > On Wed, Sep 25, 2019 at 8:34 PM Mark Adams <mfadams at lbl.gov> wrote:
> > > On Wed, Sep 25, 2019 at 6:23 PM Balay, Satish <balay at mcs.anl.gov>
> wrote:
> > >> > 18:16 (cb53a04...) ~/petsc-karl$
> > >> So this is the commit I recommended you test against - and that's what
> > >> you have got now. Please go ahead and test.
> > > I sent the log for this. This is the output:
> > > 18:16 (cb53a04...) ~/petsc-karl$ ../arch-summit-opt64idx-pgi-cuda.py
> > > PETSC_DIR=$PWD
> > >              Configuring PETSc to compile on your system
> > >                     ***** WARNING: F77 (set to
> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linux
> > >       use ./configure F77=$F77 if you really want to use that value
> > >                     ***** WARNING: Using default optimization C flags
> -O
> > >                                        You might consider manually
> setting
> > > optimal optimization flags for your system with
> > >  COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> > > examples
> > >                     ***** WARNING: You have an older version of Gnu
> make,
> > > it will work,
> > >                                         but may not support all the
> > > parallel testing options. You can install the
>  latest
> > > Gnu make with your package manager, such as brew or macports, or use
> > >             the --download-make option to get the latest Gnu make
> warning
> > > message *****
> > >               TESTING: configureMPIEXEC from
> > > config.packages.MPI(config/BuildSystem/config/packages/MPI.py:174)
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > Unable to run jsrun -g 1 with option "-n 1"
> > > Error: It is only possible to use js commands within a job allocation
> > > unless CSM is running
> > > 09-25-2019 18:20:13:224 108023 main: Error initializing RM connection.
> > > Exiting.
> > > 18:20 1 (cb53a04...) ~/petsc-karl$
> > >> [note: the branch is rebased - so 'git pull' won't work -(as you can
> > >> see from the "(forced update)" message - and '<>' status from git
> > >> prompt on balay/fix-mpiexec-shell-escape). So perhaps its easier to
> > >> deal with in detached mode - which makes this obvious]
> > > I got this <> and "fixed" it by deleting the branch and repulling it. I
> > > guess I needed to fetch also.
> > > Mark
> > >> Satish
> > >> > I will test this now but ....
> > >> > 17:52 balay/fix-mpiexec-shell-escape= ~/petsc-karl$ git fetch
> > >> > remote: Enumerating objects: 119, done.
> > >> > remote: Counting objects: 100% (119/119), done.
> > >> > remote: Compressing objects: 100% (91/91), done.
> > >> > remote: Total 119 (delta 49), reused 74 (delta 28)
> > >> > Receiving objects: 100% (119/119), 132.88 KiB | 0 bytes/s, done.
> > >> > Resolving deltas: 100% (49/49), completed with 1 local objects.
> > >> > >From https://gitlab.com/petsc/petsc
> > >> >  + b5e99a5...cb53a04 balay/fix-mpiexec-shell-escape ->
> > >> > origin/balay/fix-mpiexec-shell-escape  (forced update)
> > >> >  + ffdc635...7eeb5f9 jczhang/feature-sf-on-gpu ->
> > >> > origin/jczhang/feature-sf-on-gpu  (forced update)
> > >> >    cb9de97..f9ff08a  jolivet/fix-error-col-row ->
> > >> > origin/jolivet/fix-error-col-row
> > >> >    40ea605..de5ad60  oanam/jacobf/cell-to-ref-mapping ->
> > >> > origin/oanam/jacobf/cell-to-ref-mapping
> > >> >  + ecac953...9fb579e stefanozampini/hypre-cuda-rebased ->
> > >> > origin/stefanozampini/hypre-cuda-rebased  (forced update)
> > >> > 18:16 balay/fix-mpiexec-shell-escape<> ~/petsc-karl$ git checkout
> > >> > Note: checking out 'origin/balay/fix-mpiexec-shell-escape'.
> > >> > You are in 'detached HEAD' state. You can look around, make
> experimental
> > >> > changes and commit them, and you can discard any commits you make in
> > >> this
> > >> > state without impacting any branches by performing another checkout.
> > >> > If you want to create a new branch to retain commits you create,
> you may
> > >> > do so (now or later) by using -b with the checkout command again.
> > >> Example:
> > >> >   git checkout -b new_branch_name
> > >> > HEAD is now at cb53a04... mpiexec: fix shell escape of
> path-to-mpiexec
> > >> only
> > >> > when using autodected-path. Also spectrum MPI uses
> OMPI_MAJOR_VERSION
> > >> etc -
> > >> > so check if mpiexec supports --oversubscribe - before using it.
> > >> > On Wed, Sep 25, 2019 at 5:58 PM Balay, Satish <balay at mcs.anl.gov>
> > >> > > This is not the latest state - It should be:
> > >> > > commit cb53a042369fb946804f53931a88b58e10588da1 (HEAD ->
> > >> > > balay/fix-mpiexec-shell-escape,
> > >> > > Try:
> > >> > > git fetch
> > >> > > git checkout origin/balay/fix-mpiexec-shell-escape
> > >> > > Satish
> > >> > > > On Wed, Sep 25, 2019 at 4:57 PM Balay, Satish <
> > >> > > > > > I did test this and sent the log (error).
> > >> > > > > Mark,
> > >> > > > > I made more changes - can you retry again - and resend log.
> > >> > > > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/50ad0cb2/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/50ad0cb2/attachment-0001.obj>
