[petsc-dev] error with karlrupp/fix-cuda-streams
Balay, Satish
balay at mcs.anl.gov
Wed Sep 25 19:43:15 CDT 2019
This log is from the wrong build. It says:
Defined "VERSION_GIT" to ""v3.11.3-2242-gb5e99a5""
i.e its not with commit cb53a04
Satish
On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> Here is the log.
> On Wed, Sep 25, 2019 at 8:34 PM Mark Adams <mfadams at lbl.gov> wrote:
> > On Wed, Sep 25, 2019 at 6:23 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> >> > 18:16 (cb53a04...) ~/petsc-karl$
> >> So this is the commit I recommended you test against - and that's what
> >> you have got now. Please go ahead and test.
> > I sent the log for this. This is the output:
> > 18:16 (cb53a04...) ~/petsc-karl$ ../arch-summit-opt64idx-pgi-cuda.py
> > PETSC_DIR=$PWD
> > Configuring PETSc to compile on your system
> > ***** WARNING: F77 (set to
> > /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linux
> > use ./configure F77=$F77 if you really want to use that value ******
> > ***** WARNING: Using default optimization C flags -O
> > You might consider manually setting
> > optimal optimization flags for your system with
> > COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> > examples
> > ***** WARNING: You have an older version of Gnu make,
> > it will work,
> > but may not support all the
> > parallel testing options. You can install the
> > latest
> > Gnu make with your package manager, such as brew or macports, or use
> > the --download-make option to get the latest Gnu make warning
> > message *****
> > TESTING: configureMPIEXEC from
> > config.packages.MPI(config/BuildSystem/config/packages/MPI.py:174)
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> > Unable to run jsrun -g 1 with option "-n 1"
> > Error: It is only possible to use js commands within a job allocation
> > unless CSM is running
> > 09-25-2019 18:20:13:224 108023 main: Error initializing RM connection.
> > Exiting.
> > 18:20 1 (cb53a04...) ~/petsc-karl$
> >> [note: the branch is rebased - so 'git pull' won't work -(as you can
> >> see from the "(forced update)" message - and '<>' status from git
> >> prompt on balay/fix-mpiexec-shell-escape). So perhaps its easier to
> >> deal with in detached mode - which makes this obvious]
> > I got this <> and "fixed" it by deleting the branch and repulling it. I
> > guess I needed to fetch also.
> > Mark
> >> Satish
> >> > I will test this now but ....
> >> > 17:52 balay/fix-mpiexec-shell-escape= ~/petsc-karl$ git fetch
> >> > remote: Enumerating objects: 119, done.
> >> > remote: Counting objects: 100% (119/119), done.
> >> > remote: Compressing objects: 100% (91/91), done.
> >> > remote: Total 119 (delta 49), reused 74 (delta 28)
> >> > Receiving objects: 100% (119/119), 132.88 KiB | 0 bytes/s, done.
> >> > Resolving deltas: 100% (49/49), completed with 1 local objects.
> >> > >From https://gitlab.com/petsc/petsc
> >> > + b5e99a5...cb53a04 balay/fix-mpiexec-shell-escape ->
> >> > origin/balay/fix-mpiexec-shell-escape (forced update)
> >> > + ffdc635...7eeb5f9 jczhang/feature-sf-on-gpu ->
> >> > origin/jczhang/feature-sf-on-gpu (forced update)
> >> > cb9de97..f9ff08a jolivet/fix-error-col-row ->
> >> > origin/jolivet/fix-error-col-row
> >> > 40ea605..de5ad60 oanam/jacobf/cell-to-ref-mapping ->
> >> > origin/oanam/jacobf/cell-to-ref-mapping
> >> > + ecac953...9fb579e stefanozampini/hypre-cuda-rebased ->
> >> > origin/stefanozampini/hypre-cuda-rebased (forced update)
> >> > 18:16 balay/fix-mpiexec-shell-escape<> ~/petsc-karl$ git checkout
> >> > Note: checking out 'origin/balay/fix-mpiexec-shell-escape'.
> >> > You are in 'detached HEAD' state. You can look around, make experimental
> >> > changes and commit them, and you can discard any commits you make in
> >> this
> >> > state without impacting any branches by performing another checkout.
> >> > If you want to create a new branch to retain commits you create, you may
> >> > do so (now or later) by using -b with the checkout command again.
> >> Example:
> >> > git checkout -b new_branch_name
> >> > HEAD is now at cb53a04... mpiexec: fix shell escape of path-to-mpiexec
> >> only
> >> > when using autodected-path. Also spectrum MPI uses OMPI_MAJOR_VERSION
> >> etc -
> >> > so check if mpiexec supports --oversubscribe - before using it.
> >> > On Wed, Sep 25, 2019 at 5:58 PM Balay, Satish <balay at mcs.anl.gov>
> >> > > This is not the latest state - It should be:
> >> > > commit cb53a042369fb946804f53931a88b58e10588da1 (HEAD ->
> >> > > balay/fix-mpiexec-shell-escape, origin/balay/fix-mpiexec-shell-escape)
> >> > > Try:
> >> > > git fetch
> >> > > git checkout origin/balay/fix-mpiexec-shell-escape
> >> > > Satish
> >> > > > On Wed, Sep 25, 2019 at 4:57 PM Balay, Satish <balay at mcs.anl.gov>
> >> > > > > > I did test this and sent the log (error).
> >> > > > > Mark,
> >> > > > > I made more changes - can you retry again - and resend log.
> >> > > > > Satish
