[petsc-dev] error with karlrupp/fix-cuda-streams
Balay, Satish balay at mcs.anl.gov
Wed Sep 25 19:40:26 CDT 2019
> Unable to run jsrun -g 1 with option "-n 1"
> Error: It is only possible to use js commands within a job allocation
> unless CSM is running
Nope  this is a different error message.
The message suggests - you can't run 'jsrun -g 1 -n 1 binary' Can you try this manually and see
what you get?
jsrun -g 1 -n 1 printenv
Satish
On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> On Wed, Sep 25, 2019 at 6:23 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > > 18:16 (cb53a04...) ~/petsc-karl$
> > So this is the commit I recommended you test against - and that's what
> > you have got now. Please go ahead and test.
> I sent the log for this. This is the output:
> 18:16 (cb53a04...) ~/petsc-karl$ ../arch-summit-opt64idx-pgi-cuda.py
> PETSC_DIR=$PWD
>              Configuring PETSc to compile on your system
>                     ***** WARNING: F77 (set to
> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linux
>       use ./configure F77=$F77 if you really want to use that value ******
>                     ***** WARNING: Using default optimization C flags -O
>                                        You might consider manually setting
> optimal optimization flags for your system with
>  COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> examples
>                     ***** WARNING: You have an older version of Gnu make,
> it will work,
>                                         but may not support all the
> parallel testing options. You can install the
>        latest
> Gnu make with your package manager, such as brew or macports, or use
>             the --download-make option to get the latest Gnu make warning
> message *****
>               TESTING: configureMPIEXEC from
> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:174)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> 09-25-2019 18:20:13:224 108023 main: Error initializing RM connection.
> Exiting.
> 18:20 1 (cb53a04...) ~/petsc-karl$
> > [note: the branch is rebased - so 'git pull' won't work -(as you can
> > see from the "(forced update)" message - and '<>' status from git
> > prompt on balay/fix-mpiexec-shell-escape). So perhaps its easier to
> > deal with in detached mode - which makes this obvious]
> I got this <> and "fixed" it by deleting the branch and repulling it. I
> guess I needed to fetch also.
> Mark
> > Satish
> > > I will test this now but ....
> > > 17:52 balay/fix-mpiexec-shell-escape= ~/petsc-karl$ git fetch
> > > remote: Enumerating objects: 119, done.
> > > remote: Counting objects: 100% (119/119), done.
> > > remote: Compressing objects: 100% (91/91), done.
> > > remote: Total 119 (delta 49), reused 74 (delta 28)
> > > Receiving objects: 100% (119/119), 132.88 KiB | 0 bytes/s, done.
> > > Resolving deltas: 100% (49/49), completed with 1 local objects.
> > > >From https://gitlab.com/petsc/petsc
> > >  + b5e99a5...cb53a04 balay/fix-mpiexec-shell-escape ->
> > > origin/balay/fix-mpiexec-shell-escape  (forced update)
> > >  + ffdc635...7eeb5f9 jczhang/feature-sf-on-gpu ->
> > > origin/jczhang/feature-sf-on-gpu  (forced update)
> > >    cb9de97..f9ff08a  jolivet/fix-error-col-row ->
> > > origin/jolivet/fix-error-col-row
> > >    40ea605..de5ad60  oanam/jacobf/cell-to-ref-mapping ->
> > > origin/oanam/jacobf/cell-to-ref-mapping
> > >  + ecac953...9fb579e stefanozampini/hypre-cuda-rebased ->
> > > origin/stefanozampini/hypre-cuda-rebased  (forced update)
> > > 18:16 balay/fix-mpiexec-shell-escape<> ~/petsc-karl$ git checkout
> > > Note: checking out 'origin/balay/fix-mpiexec-shell-escape'.
> > > You are in 'detached HEAD' state. You can look around, make experimental
> > > changes and commit them, and you can discard any commits you make in this
> > > state without impacting any branches by performing another checkout.
> > > If you want to create a new branch to retain commits you create, you may
> > > do so (now or later) by using -b with the checkout command again.
> > Example:
> > >   git checkout -b new_branch_name
> > > HEAD is now at cb53a04... mpiexec: fix shell escape of path-to-mpiexec
> > only
> > > when using autodected-path. Also spectrum MPI uses OMPI_MAJOR_VERSION
> > etc -
> > > so check if mpiexec supports --oversubscribe - before using it.
> > > On Wed, Sep 25, 2019 at 5:58 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > > >             Defined "VERSION_GIT" to ""v3.11.3-2242-gb5e99a5""
> > > > This is not the latest state - It should be:
> > > > commit cb53a042369fb946804f53931a88b58e10588da1 (HEAD ->
> > > > balay/fix-mpiexec-shell-escape, origin/balay/fix-mpiexec-shell-escape)
> > > > Try:
> > > > git fetch
> > > > git checkout origin/balay/fix-mpiexec-shell-escape
> > > > Satish
> > > > > On Wed, Sep 25, 2019 at 4:57 PM Balay, Satish <balay at mcs.anl.gov>
> > > > > > > I did test this and sent the log (error).
> > > > > > Mark,
> > > > > > I made more changes - can you retry again - and resend log.
> > > > > > Satish
