[petsc-dev] error with karlrupp/fix-cuda-streams
Mark Adams mfadams at lbl.gov
Wed Sep 25 21:12:05 CDT 2019
On Wed, Sep 25, 2019 at 8:40 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > Unable to run jsrun -g 1 with option "-n 1"
> > Error: It is only possible to use js commands within a job allocation
> > unless CSM is running
> Nope  this is a different error message.
> The message suggests - you can't run 'jsrun -g 1 -n 1 binary' Can you try
> this manually and see
> what you get?
> jsrun -g 1 -n 1 printenv
I tested this earlier today and originally when I was figuring out the/a
minimal run command:
22:08  /gpfs/alpine/geo127/scratch/adams$ jsrun -g 1 -n 1 printenv
GIT_PS1_SHOWDIRTYSTATE=1
XDG_SESSION_ID=494
SHELL=/bin/bash
HISTSIZE=100
PETSC_ARCH=arch-summit-opt64-pgi-cuda
SSH_CLIENT=160.91.202.152 48626 22
LC_ALL=
USER=adams
> Satish
> On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> > On Wed, Sep 25, 2019 at 6:23 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > > > 18:16 (cb53a04...) ~/petsc-karl$
> > > So this is the commit I recommended you test against - and that's what
> > > you have got now. Please go ahead and test.
> > I sent the log for this. This is the output:
> > 18:16 (cb53a04...) ~/petsc-karl$ ../arch-summit-opt64idx-pgi-cuda.py
> > PETSC_DIR=$PWD
> >              Configuring PETSc to compile on your system
> >                     ***** WARNING: F77 (set to
> /autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/pgi-19.4-6acz4xyqjlpoaonjiiqjme2aknrfnzoy/linux
> >       use ./configure F77=$F77 if you really want to use that value
> >                     ***** WARNING: Using default optimization C flags -O
> >                                        You might consider manually
> setting
> > optimal optimization flags for your system with
> >  COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> > examples
> >                     ***** WARNING: You have an older version of Gnu make,
> > it will work,
> >                                         but may not support all the
> > parallel testing options. You can install the
> >        latest
> > Gnu make with your package manager, such as brew or macports, or use
> >             the --download-make option to get the latest Gnu make warning
> > message *****
> >               TESTING: configureMPIEXEC from
> > config.packages.MPI(config/BuildSystem/config/packages/MPI.py:174)
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > 09-25-2019 18:20:13:224 108023 main: Error initializing RM connection.
> > Exiting.
> > 18:20 1 (cb53a04...) ~/petsc-karl$
> > > [note: the branch is rebased - so 'git pull' won't work -(as you can
> > > see from the "(forced update)" message - and '<>' status from git
> > > prompt on balay/fix-mpiexec-shell-escape). So perhaps its easier to
> > > deal with in detached mode - which makes this obvious]
> > I got this <> and "fixed" it by deleting the branch and repulling it. I
> > guess I needed to fetch also.
> > Mark
> > > Satish
> > > > I will test this now but ....
> > > > 17:52 balay/fix-mpiexec-shell-escape= ~/petsc-karl$ git fetch
> > > > remote: Enumerating objects: 119, done.
> > > > remote: Counting objects: 100% (119/119), done.
> > > > remote: Compressing objects: 100% (91/91), done.
> > > > remote: Total 119 (delta 49), reused 74 (delta 28)
> > > > Receiving objects: 100% (119/119), 132.88 KiB | 0 bytes/s, done.
> > > > Resolving deltas: 100% (49/49), completed with 1 local objects.
> > > > >From https://gitlab.com/petsc/petsc
> > > >  + b5e99a5...cb53a04 balay/fix-mpiexec-shell-escape ->
> > > > origin/balay/fix-mpiexec-shell-escape  (forced update)
> > > >  + ffdc635...7eeb5f9 jczhang/feature-sf-on-gpu ->
> > > > origin/jczhang/feature-sf-on-gpu  (forced update)
> > > >    cb9de97..f9ff08a  jolivet/fix-error-col-row ->
> > > > origin/jolivet/fix-error-col-row
> > > >    40ea605..de5ad60  oanam/jacobf/cell-to-ref-mapping ->
> > > > origin/oanam/jacobf/cell-to-ref-mapping
> > > >  + ecac953...9fb579e stefanozampini/hypre-cuda-rebased ->
> > > > origin/stefanozampini/hypre-cuda-rebased  (forced update)
> > > > 18:16 balay/fix-mpiexec-shell-escape<> ~/petsc-karl$ git checkout
> > > > Note: checking out 'origin/balay/fix-mpiexec-shell-escape'.
> > > > You are in 'detached HEAD' state. You can look around, make
> experimental
> > > > changes and commit them, and you can discard any commits you make in
> this
> > > > state without impacting any branches by performing another checkout.
> > > > If you want to create a new branch to retain commits you create, you
> may
> > > > do so (now or later) by using -b with the checkout command again.
> > > Example:
> > > >   git checkout -b new_branch_name
> > > > HEAD is now at cb53a04... mpiexec: fix shell escape of
> path-to-mpiexec
> > > only
> > > > when using autodected-path. Also spectrum MPI uses OMPI_MAJOR_VERSION
> > > etc -
> > > > so check if mpiexec supports --oversubscribe - before using it.
> > > > On Wed, Sep 25, 2019 at 5:58 PM Balay, Satish <balay at mcs.anl.gov>
> wrote:
> > > > >             Defined "VERSION_GIT" to ""v3.11.3-2242-gb5e99a5""
> > > > > This is not the latest state - It should be:
> > > > > commit cb53a042369fb946804f53931a88b58e10588da1 (HEAD ->
> > > > > balay/fix-mpiexec-shell-escape,
> origin/balay/fix-mpiexec-shell-escape)
> > > > > Try:
> > > > > git fetch
> > > > > git checkout origin/balay/fix-mpiexec-shell-escape
> > > > > Satish
> > > > > > On Wed, Sep 25, 2019 at 4:57 PM Balay, Satish <balay at mcs.anl.gov
> > > > > > > > I did test this and sent the log (error).
> > > > > > > Mark,
> > > > > > > I made more changes - can you retry again - and resend log.
> > > > > > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/415690d1/attachment-0001.html>
