[petsc-dev] TAP file and testing error
Stefano Zampini stefano.zampini at gmail.com
Wed Sep 25 14:51:01 CDT 2019
If we specify a PETSC_ARCH with a trailing slash, the current testing
makefile fails. Can this be fixed?
*zampins at vulture*:*~/Devel/petsc*$ make -f gmakefile.test test
globsearch="*densecuda*" PETSC_ARCH=arch-gpu-double-unifmem/
touch: cannot touch
'./arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_tap.log':
No such file or directory
touch: cannot touch
'./arch-gpu-double-unifmem//tests/test_arch-gpu-double-unifmem/_err.log':
No such file or directory--
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/9ea2bcdd/attachment.html>
