[petsc-dev] Broken MatMatMult_MPIAIJ_MPIDense
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Mon Sep 23 11:32:48 CDT 2019
Hong,
You should probably cherry pick https://gitlab.com/petsc/petsc/commit/93d7d1d6d29b0d66b5629a261178b832a925de80?merge_request_iid=2069 <https://gitlab.com/petsc/petsc/commit/93d7d1d6d29b0d66b5629a261178b832a925de80?merge_request_iid=2069> (and remove the MatNest part).
This fixes a similar issue in MatTransposeMatMult with nontrivial LDAs.
Since this commit is part of a feature MR that is unlikely to be ready for tomorrow, this fix (as of now) is also unlikely to be in master for the release.
Pierre
> On 23 Sep 2019, at 6:02 PM, Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Barry:
> As a hack for this release could you have the Numeric portion of the multiply routines check if the symbolic data is there and if not just call the symbolic an attach the needed data? You might need to have a utility function that does all the symbolic part except the allocation of the matrix and then call this from the numeric part as well as the real symbolic part.
> I'm working on this now. I was not aware of MatSeqDenseSetLDA() which changes pattern of data access in seqdense matrix.
> Pierre's patch:
> "change Bm here https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/aij/mpi/mpimatmatmult.c.html#line549 <https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/aij/mpi/mpimatmatmult.c.html#line549> to the LDA of B"
> fix this bug. I'll further test it and submit a pull request.
> Then, I'll check slepc's bug report.
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190923/a7b81007/attachment.html>
