[petsc-dev] Broken MatMatMult_MPIAIJ_MPIDense
Zhang, Hong hzhang at mcs.anl.gov
Mon Sep 23 11:02:30 CDT 2019
Barry:
    As a hack for this release could you have the Numeric portion of the multiply routines check if the symbolic data is there and if not just call the symbolic an attach the needed data? You might need to have a utility function that does all the symbolic part except the allocation of the matrix and then call this from the numeric part as well as the real symbolic part.
I'm working on this now.  I was not aware of MatSeqDenseSetLDA() which changes pattern of data access in seqdense matrix.
Pierre's patch:
"change Bm here https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/aij/mpi/mpimatmatmult.c.html#line549 to the LDA of B"
fix this bug. I'll further test it and submit a pull request.
Then, I'll check slepc's bug report.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190923/852ecee8/attachment.html>
