[petsc-dev] Broken MatMatMult_MPIAIJ_MPIDense
Zhang, Hong
hzhang at mcs.anl.gov
Mon Sep 23 13:18:11 CDT 2019
Done. See https://gitlab.com/petsc/petsc/commit/85ec510f49531057ebfe1fb641fe93a36371878e
Hong
On Mon, Sep 23, 2019 at 11:32 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr<mailto:pierre.jolivet at enseeiht.fr>> wrote:
Hong,
You should probably cherry pick https://gitlab.com/petsc/petsc/commit/93d7d1d6d29b0d66b5629a261178b832a925de80?merge_request_iid=2069 (and remove the MatNest part).
This fixes a similar issue in MatTransposeMatMult with nontrivial LDAs.
Since this commit is part of a feature MR that is unlikely to be ready for tomorrow, this fix (as of now) is also unlikely to be in master for the release.
Pierre
On 23 Sep 2019, at 6:02 PM, Zhang, Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> wrote:
Barry:
As a hack for this release could you have the Numeric portion of the multiply routines check if the symbolic data is there and if not just call the symbolic an attach the needed data? You might need to have a utility function that does all the symbolic part except the allocation of the matrix and then call this from the numeric part as well as the real symbolic part.
I'm working on this now. I was not aware of MatSeqDenseSetLDA() which changes pattern of data access in seqdense matrix.
Pierre's patch:
"change Bm here https://www.mcs.anl.gov/petsc/petsc-dev/src/mat/impls/aij/mpi/mpimatmatmult.c.html#line549 to the LDA of B"
fix this bug. I'll further test it and submit a pull request.
Then, I'll check slepc's bug report.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190923/b339c994/attachment.html>
