[petsc-dev] Master broken after changes to PetscSection headers
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Sep 19 05:39:34 CDT 2019
> On Sep 19, 2019, at 1:23 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Sep 19, 2019 at 6:21 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Thu, Sep 19, 2019 at 6:20 AM Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
> So why it is in the vec package?
> Its in IS, so if anything it should go in petscis.h. I will move it there.
> Now that we are doing this. I think petscsf.h belongs there too, not just the types.
Why? In order to use petscis.h You just need to forward declare PetscSF, which is what petscfstypes.h is supposed to do.
Our public header should just pass the test of preprocessing
#include <petscxxx.h>
Without warning or errors. We should add this to the makefile rules
>    Matt
>    Matt
> Il Gio 19 Set 2019, 13:17 Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> ha scritto:
> I made a new MR. DMLabel uses Section, whereas nothing else in Vec does.
>    Matt
> On Thu, Sep 19, 2019 at 6:03 AM Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
> Petscsection is part of the vec package. It belongs to petscvec.h
> Il Gio 19 Set 2019, 12:50 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>> ha scritto:
>> On 19 Sep 2019, at 11:25, Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>> I pushed the fix to the branch. Can we remerge it?
> I think best way would be to create another MR.
> You should also add
>   #include <petscsection.h>
> to petscdmlabel.h.
> This which will also satisfy Lisandro's point.
> Vaclav
>> Also, I do not understand why tests did not catch this. Its obvious what happened. I added that header
>> to convert.c instead of convest.c.
>>    Matt
>> On Thu, Sep 19, 2019 at 5:19 AM Stefano Zampini via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>> How come this was not caught by the tests? I think we have tests with -Werror
>> Il Gio 19 Set 2019, 12:15 Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> ha scritto:
>> The warnings below are from a C build. A C++ build fails right away.
>> We need to `#include <petscsection.h>` somewhere in the public headers, at least such that  `#include <petsc.h>` in user code works.
>> $ git grep petscsection include/
>> include/petsc/private/sectionimpl.h:#include <petscsection.h>
>> include/petscis.h:#include <petscsectiontypes.h>
>> include/petscsection.h:#include <petscsectiontypes.h>
>> /home/devel/petsc/dev/src/snes/utils/convest.c: In function ‘PetscConvEstGetConvRate’:
>> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning: implicit declaration of function ‘PetscSectionGetField’; did you mean ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>>   293 |       ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>>       |              PetscSectionVecView
>> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning: implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’ [-Wimplicit-function-declaration]
>>   294 |       ierr = PetscSectionGetConstrainedStorageSize(fs, &lsize);CHKERRQ(ierr);
>> Lisandro Dalcin
>> Research Scientist
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/ <http://ecrc.kaust.edu.sa/>
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/4d2236cc/attachment.html>
