[petsc-dev] Master broken after changes to PetscSection headers
Matthew Knepley
knepley at gmail.com
Thu Sep 19 05:23:43 CDT 2019
On Thu, Sep 19, 2019 at 6:21 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Sep 19, 2019 at 6:20 AM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> So why it is in the vec package?
> Its in IS, so if anything it should go in petscis.h. I will move it there.
Now that we are doing this. I think petscsf.h belongs there too, not just
the types.
Matt
> Matt
>> Il Gio 19 Set 2019, 13:17 Matthew Knepley <knepley at gmail.com> ha scritto:
>>> I made a new MR. DMLabel uses Section, whereas nothing else in Vec does.
>>> Matt
>>> On Thu, Sep 19, 2019 at 6:03 AM Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>>> Petscsection is part of the vec package. It belongs to petscvec.h
>>>> Il Gio 19 Set 2019, 12:50 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha
>>>> scritto:
>>>>> On 19 Sep 2019, at 11:25, Matthew Knepley via petsc-dev <
>>>>> petsc-dev at mcs.anl.gov> wrote:
>>>>> I pushed the fix to the branch. Can we remerge it?
>>>>> I think best way would be to create another MR.
>>>>> You should also add
>>>>> #include <petscsection.h>
>>>>> to petscdmlabel.h.
>>>>> This which will also satisfy Lisandro's point.
>>>>> Vaclav
>>>>> Also, I do not understand why tests did not catch this. Its obvious
>>>>> what happened. I added that header
>>>>> to convert.c instead of convest.c.
>>>>> Matt
>>>>> On Thu, Sep 19, 2019 at 5:19 AM Stefano Zampini via petsc-dev <
>>>>>> How come this was not caught by the tests? I think we have tests with
>>>>>> -Werror
>>>>>> Il Gio 19 Set 2019, 12:15 Lisandro Dalcin via petsc-dev <
>>>>>> petsc-dev at mcs.anl.gov> ha scritto:
>>>>>>> The warnings below are from a C build. A C++ build fails right away.
>>>>>>> We need to `#include <petscsection.h>` somewhere in the public
>>>>>>> headers, at least such that `#include <petsc.h>` in user code works.
>>>>>>> $ git grep petscsection include/
>>>>>>> include/petsc/private/sectionimpl.h:#include <petscsection.h>
>>>>>>> include/petscis.h:#include <petscsectiontypes.h>
>>>>>>> include/petscsection.h:#include <petscsectiontypes.h>
>>>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c: In function
>>>>>>> ‘PetscConvEstGetConvRate’:
>>>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning:
>>>>>>> implicit declaration of function ‘PetscSectionGetField’; did you mean
>>>>>>> ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>>>>>>> 293 | ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>>>>>>> | PetscSectionVecView
>>>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning:
>>>>>>> implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’
>>>>>>> 294 | ierr = PetscSectionGetConstrainedStorageSize(fs,
>>>>>>> &lsize);CHKERRQ(ierr);
>>>>>>> Lisandro Dalcin
>>>>>>> Research Scientist
>>>>>>> Extreme Computing Research Center (ECRC)
>>>>>>> King Abdullah University of Science and Technology (KAUST)
>>>>>>> http://ecrc.kaust.edu.sa/
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/62d22500/attachment-0001.html>
