[petsc-dev] Master broken after changes to PetscSection headers
Matthew Knepley
knepley at gmail.com
Thu Sep 19 05:21:30 CDT 2019
On Thu, Sep 19, 2019 at 6:20 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> So why it is in the vec package?
Its in IS, so if anything it should go in petscis.h. I will move it there.
Matt
> Il Gio 19 Set 2019, 13:17 Matthew Knepley <knepley at gmail.com> ha scritto:
>> I made a new MR. DMLabel uses Section, whereas nothing else in Vec does.
>> Matt
>> On Thu, Sep 19, 2019 at 6:03 AM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> Petscsection is part of the vec package. It belongs to petscvec.h
>>> Il Gio 19 Set 2019, 12:50 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha
>>> scritto:
>>>> On 19 Sep 2019, at 11:25, Matthew Knepley via petsc-dev <
>>>> petsc-dev at mcs.anl.gov> wrote:
>>>> I pushed the fix to the branch. Can we remerge it?
>>>> I think best way would be to create another MR.
>>>> You should also add
>>>> #include <petscsection.h>
>>>> to petscdmlabel.h.
>>>> This which will also satisfy Lisandro's point.
>>>> Vaclav
>>>> Also, I do not understand why tests did not catch this. Its obvious
>>>> what happened. I added that header
>>>> to convert.c instead of convest.c.
>>>> Matt
>>>> On Thu, Sep 19, 2019 at 5:19 AM Stefano Zampini via petsc-dev <
>>>>> How come this was not caught by the tests? I think we have tests with
>>>>> -Werror
>>>>> Il Gio 19 Set 2019, 12:15 Lisandro Dalcin via petsc-dev <
>>>>> petsc-dev at mcs.anl.gov> ha scritto:
>>>>>> The warnings below are from a C build. A C++ build fails right away.
>>>>>> We need to `#include <petscsection.h>` somewhere in the public
>>>>>> headers, at least such that `#include <petsc.h>` in user code works.
>>>>>> $ git grep petscsection include/
>>>>>> include/petsc/private/sectionimpl.h:#include <petscsection.h>
>>>>>> include/petscis.h:#include <petscsectiontypes.h>
>>>>>> include/petscsection.h:#include <petscsectiontypes.h>
>>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c: In function
>>>>>> ‘PetscConvEstGetConvRate’:
>>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning:
>>>>>> implicit declaration of function ‘PetscSectionGetField’; did you mean
>>>>>> ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>>>>>> 293 | ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>>>>>> | PetscSectionVecView
>>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning:
>>>>>> implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’
>>>>>> 294 | ierr = PetscSectionGetConstrainedStorageSize(fs,
>>>>>> &lsize);CHKERRQ(ierr);
>>>>>> Lisandro Dalcin
>>>>>> Research Scientist
>>>>>> Extreme Computing Research Center (ECRC)
>>>>>> King Abdullah University of Science and Technology (KAUST)
>>>>>> http://ecrc.kaust.edu.sa/
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/924c75f0/attachment.html>
