[petsc-dev] Master broken after changes to PetscSection headers
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Sep 19 05:19:57 CDT 2019
So why it is in the vec package?
Il Gio 19 Set 2019, 13:17 Matthew Knepley <knepley at gmail.com> ha scritto:
> I made a new MR. DMLabel uses Section, whereas nothing else in Vec does.
>    Matt
> On Thu, Sep 19, 2019 at 6:03 AM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> Petscsection is part of the vec package. It belongs to petscvec.h
>> Il Gio 19 Set 2019, 12:50 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha
>> scritto:
>>> On 19 Sep 2019, at 11:25, Matthew Knepley via petsc-dev <
>>> petsc-dev at mcs.anl.gov> wrote:
>>> I pushed the fix to the branch. Can we remerge it?
>>> I think best way would be to create another MR.
>>> You should also add
>>>   #include <petscsection.h>
>>> to petscdmlabel.h.
>>> This which will also satisfy Lisandro's point.
>>> Vaclav
>>> Also, I do not understand why tests did not catch this. Its obvious what
>>> happened. I added that header
>>> to convert.c instead of convest.c.
>>>    Matt
>>> On Thu, Sep 19, 2019 at 5:19 AM Stefano Zampini via petsc-dev <
>>>> How come this was not caught by the tests? I think we have tests with
>>>> -Werror
>>>> Il Gio 19 Set 2019, 12:15 Lisandro Dalcin via petsc-dev <
>>>> petsc-dev at mcs.anl.gov> ha scritto:
>>>>> The warnings below are from a C build. A C++ build fails right away.
>>>>> We need to `#include <petscsection.h>` somewhere in the public
>>>>> headers, at least such that  `#include <petsc.h>` in user code works.
>>>>> $ git grep petscsection include/
>>>>> include/petsc/private/sectionimpl.h:#include <petscsection.h>
>>>>> include/petscis.h:#include <petscsectiontypes.h>
>>>>> include/petscsection.h:#include <petscsectiontypes.h>
>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c: In function
>>>>> ‘PetscConvEstGetConvRate’:
>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning:
>>>>> implicit declaration of function ‘PetscSectionGetField’; did you mean
>>>>> ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>>>>>   293 |       ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>>>>>       |              PetscSectionVecView
>>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning:
>>>>> implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’
>>>>>   294 |       ierr = PetscSectionGetConstrainedStorageSize(fs,
>>>>> &lsize);CHKERRQ(ierr);
>>>>> Lisandro Dalcin
>>>>> Research Scientist
>>>>> Extreme Computing Research Center (ECRC)
>>>>> King Abdullah University of Science and Technology (KAUST)
>>>>> http://ecrc.kaust.edu.sa/
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/f3628e81/attachment.html>
