[petsc-dev] Master broken after changes to PetscSection headers
Thu Sep 19 05:16:46 CDT 2019
I made a new MR. DMLabel uses Section, whereas nothing else in Vec does.
   Matt
On Thu, Sep 19, 2019 at 6:03 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Petscsection is part of the vec package. It belongs to petscvec.h
> Il Gio 19 Set 2019, 12:50 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha
> scritto:
>> On 19 Sep 2019, at 11:25, Matthew Knepley via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> I pushed the fix to the branch. Can we remerge it?
>> I think best way would be to create another MR.
>> You should also add
>>   #include <petscsection.h>
>> to petscdmlabel.h.
>> This which will also satisfy Lisandro's point.
>> Vaclav
>> Also, I do not understand why tests did not catch this. Its obvious what
>> happened. I added that header
>> to convert.c instead of convest.c.
>>    Matt
>> On Thu, Sep 19, 2019 at 5:19 AM Stefano Zampini via petsc-dev <
>>> How come this was not caught by the tests? I think we have tests with
>>> -Werror
>>> Il Gio 19 Set 2019, 12:15 Lisandro Dalcin via petsc-dev <
>>> petsc-dev at mcs.anl.gov> ha scritto:
>>>> The warnings below are from a C build. A C++ build fails right away.
>>>> We need to `#include <petscsection.h>` somewhere in the public headers,
>>>> at least such that  `#include <petsc.h>` in user code works.
>>>> $ git grep petscsection include/
>>>> include/petsc/private/sectionimpl.h:#include <petscsection.h>
>>>> include/petscis.h:#include <petscsectiontypes.h>
>>>> include/petscsection.h:#include <petscsectiontypes.h>
>>>> /home/devel/petsc/dev/src/snes/utils/convest.c: In function
>>>> ‘PetscConvEstGetConvRate’:
>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:293:14: warning:
>>>> implicit declaration of function ‘PetscSectionGetField’; did you mean
>>>> ‘PetscSectionVecView’? [-Wimplicit-function-declaration]
>>>>   293 |       ierr = PetscSectionGetField(s, f, &fs);CHKERRQ(ierr);
>>>>       |              PetscSectionVecView
>>>> /home/devel/petsc/dev/src/snes/utils/convest.c:294:14: warning:
>>>> implicit declaration of function ‘PetscSectionGetConstrainedStorageSize’
>>>>   294 |       ierr = PetscSectionGetConstrainedStorageSize(fs,
>>>> &lsize);CHKERRQ(ierr);
>>>> Lisandro Dalcin
>>>> Research Scientist
>>>> Extreme Computing Research Center (ECRC)
>>>> King Abdullah University of Science and Technology (KAUST)
>>>> http://ecrc.kaust.edu.sa/
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/c02ae7cc/attachment-0001.html>
