[petsc-dev] section negative offsets
    Hapla  Vaclav
    vaclav.hapla at erdw.ethz.ch
    Tue Sep 17 07:58:36 CDT 2019
On 17 Sep 2019, at 14:48, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, Sep 17, 2019 at 8:34 AM Hapla Vaclav via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Can PetscSection offsets other than unset be negative? I.e. could the offset value of -1 be an indicator it was not set and needs to be computed?
No, we use negative offsets for off-process things.
And chart bounds?
   Matt
Vaclav
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190917/323a47b3/attachment.html>
