[petsc-dev] section negative offsets
Tue Sep 17 07:48:18 CDT 2019
On Tue, Sep 17, 2019 at 8:34 AM Hapla Vaclav via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Can PetscSection offsets other than unset be negative? I.e. could the
> offset value of -1 be an indicator it was not set and needs to be computed?
No, we use negative offsets for off-process things.
   Matt
> Thanks,
> Vaclav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190917/7a51cb05/attachment.html>
