[petsc-dev] section negative offsets
Matthew Knepley
knepley at gmail.com
Tue Sep 17 08:01:52 CDT 2019
On Tue, Sep 17, 2019 at 8:58 AM Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
wrote:
> On 17 Sep 2019, at 14:48, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 17, 2019 at 8:34 AM Hapla Vaclav via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> Can PetscSection offsets other than unset be negative? I.e. could the
>> offset value of -1 be an indicator it was not set and needs to be computed?
> No, we use negative offsets for off-process things.
> And chart bounds?
Hmm, I have never used negative chart bounds, and I am not big on requiring
non-negativity since someone might
think of a good use for them.
Matt
> Matt
>> Thanks,
>> Vaclav
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190917/2151347a/attachment.html>
