[petsc-dev] Gitlab notifications
    Jed Brown
    jed at jedbrown.org
    Thu Sep 12 11:24:22 CDT 2019
I added it.
"Balay, Satish" <balay at mcs.anl.gov> writes:
> Ah good to know.
> I've tried adding back 'Team' with 'petsc/developers' listed - but
> 'petsc/developers' keeps disappearing from it. Not sure whats
> happening..
> thanks,
> Satish
> On Thu, 12 Sep 2019, Scott Kruger wrote:
>> Here's what I did:
>> Settings -> Notifications -> developers + Participate
>> The default is "Global".  "Participate" is what I'm using now.
>> There is a "Custom", but it confuses me since it says you can
>> use it to match "Participate", but you can't do something like:
>> Email all new issues, but only show me the MR's I am mentioned
>> in or own.
>> Scott
>> On 9/12/19 7:39 AM, Balay, Satish via petsc-dev wrote:
>> > On Thu, 12 Sep 2019, Jed Brown via petsc-dev wrote:
>> >> Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> >>> On Thu, Sep 12, 2019 at 9:05 AM Balay, Satish via petsc-dev <
>> >>> petsc-dev at mcs.anl.gov> wrote:
>> >>>> When a new MR is created, approval rules default to 'Integration' and
>> >>>> 'Team'
>> >>>> So everyone in the team probably receives emails on all MRs. Now that
>> >>>> we have CODEOWNERS setup - perhaps the Team should be removed?
>> >>> Can you explain CODEOWNERS to me? I cannot find it on the GItlab site. I
>> >>> want to see every MR.
>> >> https://docs.gitlab.com/ee/user/project/code_owners.html
>> >> We currently require approval from Integration (of which you are a
>> >> member) and a code owner (as specified in the file).
>> >> We used to have optional approvals from any other developer, but Satish
>> >> just removed that due to this notification thing, which I guess means
>> >> that any other developer (non-integrator, non-owner) should just comment
>> >> their approval if they find time to review.
>> > Ah - forgot the primary purpose of having 'Team' in the 'approve' list.
>> > Is there a way to disable notifications for team  - unless they participate?
>> > Satish
