[petsc-dev] Gitlab notifications
    Balay, Satish
    balay at mcs.anl.gov
    Thu Sep 12 10:56:31 CDT 2019
Ah good to know.
I've tried adding back 'Team' with 'petsc/developers' listed - but
'petsc/developers' keeps disappearing from it. Not sure whats
happening..
thanks,
Satish
On Thu, 12 Sep 2019, Scott Kruger wrote:
> Here's what I did:
> Settings -> Notifications -> developers + Participate
> The default is "Global".  "Participate" is what I'm using now.
> There is a "Custom", but it confuses me since it says you can
> use it to match "Participate", but you can't do something like:
> Email all new issues, but only show me the MR's I am mentioned
> in or own.
> Scott
> On 9/12/19 7:39 AM, Balay, Satish via petsc-dev wrote:
> > On Thu, 12 Sep 2019, Jed Brown via petsc-dev wrote:
> >> Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> >>> On Thu, Sep 12, 2019 at 9:05 AM Balay, Satish via petsc-dev <
> >>> petsc-dev at mcs.anl.gov> wrote:
> >>>> When a new MR is created, approval rules default to 'Integration' and
> >>>> 'Team'
> >>>> So everyone in the team probably receives emails on all MRs. Now that
> >>>> we have CODEOWNERS setup - perhaps the Team should be removed?
> >>> Can you explain CODEOWNERS to me? I cannot find it on the GItlab site. I
> >>> want to see every MR.
> >> https://docs.gitlab.com/ee/user/project/code_owners.html
> >> We currently require approval from Integration (of which you are a
> >> member) and a code owner (as specified in the file).
> >> We used to have optional approvals from any other developer, but Satish
> >> just removed that due to this notification thing, which I guess means
> >> that any other developer (non-integrator, non-owner) should just comment
> >> their approval if they find time to review.
> > Ah - forgot the primary purpose of having 'Team' in the 'approve' list.
> > Is there a way to disable notifications for team  - unless they participate?
> > Satish
