[petsc-dev] Gitlab notifications
Scott Kruger
kruger at txcorp.com
Thu Sep 12 10:14:26 CDT 2019
Here's what I did:
Settings -> Notifications -> developers + Participate
The default is "Global". "Participate" is what I'm using now.
There is a "Custom", but it confuses me since it says you can
use it to match "Participate", but you can't do something like:
Email all new issues, but only show me the MR's I am mentioned
in or own.
Scott
On 9/12/19 7:39 AM, Balay, Satish via petsc-dev wrote:
> On Thu, 12 Sep 2019, Jed Brown via petsc-dev wrote:
>> Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>>> On Thu, Sep 12, 2019 at 9:05 AM Balay, Satish via petsc-dev <
>>> petsc-dev at mcs.anl.gov> wrote:
>>>> When a new MR is created, approval rules default to 'Integration' and
>>>> 'Team'
>>>> So everyone in the team probably receives emails on all MRs. Now that
>>>> we have CODEOWNERS setup - perhaps the Team should be removed?
>>> Can you explain CODEOWNERS to me? I cannot find it on the GItlab site. I
>>> want to see every MR.
>> https://docs.gitlab.com/ee/user/project/code_owners.html
>> We currently require approval from Integration (of which you are a
>> member) and a code owner (as specified in the file).
>> We used to have optional approvals from any other developer, but Satish
>> just removed that due to this notification thing, which I guess means
>> that any other developer (non-integrator, non-owner) should just comment
>> their approval if they find time to review.
> Ah - forgot the primary purpose of having 'Team' in the 'approve' list.
> Is there a way to disable notifications for team - unless they participate?
> Satish
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
