[petsc-dev] I think the test system is broken in master
Matthew Knepley
knepley at gmail.com
Wed Oct 23 15:22:17 CDT 2019
On Wed, Oct 23, 2019 at 4:20 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> Ah - this report has no relevant context included :(
> Ok - checking about - I see you are referring to failures at
> https://gitlab.com/petsc/petsc/pipelines/91045019
> And asserting that master is broken. Ok - to check - I've started a
> pipeline on current master at:
> https://gitlab.com/petsc/petsc/pipelines/91062141
I am not saying the master branch tests are failing. I am saying that
running the
test system with REPLACE=1 is no longer working correctly.
Matt
> Satish
> On Wed, 23 Oct 2019, Matthew Knepley via petsc-dev wrote:
> > I just rebased my branch on master, and now with REPLACE=1 I am getting
> > not ok diff-ksp_ksp_tutorials-ex70_fetidp # Error code: 1
> > # 1,2d0
> > # < DMSWARM_PIC: Using method CellDM->LocatePoints
> > # < DMSWARM_PIC: Using method CellDM->GetNeigbors
> > # mv'ing ex70_fetidp.tmp -->
> /var/folders/hk/tc1pd0g57l78rpt0lttc1sfh0000gn/T/petscdiff.XXXXXX.fjHMBkGr
> > I would really liked to get this fixed as fast as possible since it will
> > hold up all development.
> > Thanks,
> > Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191023/4d5314e1/attachment-0001.html>
