[petsc-dev] I think the test system is broken in master
    Balay, Satish
    balay at mcs.anl.gov
    Wed Oct 23 15:54:03 CDT 2019
On Wed, 23 Oct 2019, Matthew Knepley via petsc-dev wrote:
> On Wed, Oct 23, 2019 at 4:20 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> I am not saying the master branch tests are failing. I am saying that
> running the
> test system with REPLACE=1 is no longer working correctly.
ok.
> > > I just rebased my branch on master, and now with REPLACE=1 I am getting
> > > not ok diff-ksp_ksp_tutorials-ex70_fetidp # Error code: 1
> > > #       1,2d0
> > > #       <   DMSWARM_PIC: Using method CellDM->LocatePoints
> > > #       <   DMSWARM_PIC: Using method CellDM->GetNeigbors
> > > #       mv'ing ex70_fetidp.tmp -->
> > /var/folders/hk/tc1pd0g57l78rpt0lttc1sfh0000gn/T/petscdiff.XXXXXX.fjHMBkGr
the destination of the 'mv' is wrong. So likely a bug in REPLACE wrt testset
[as non-testset example is working fine for me]
[and not something that recently broke - so rebase with latest master
was not a factor - as v3.12 also has this breakage]
Scott might have to take a look at this..
Satish
