[petsc-dev] I think the test system is broken in master
Balay, Satish balay at mcs.anl.gov
Wed Oct 23 15:20:51 CDT 2019
Ah - this report has no relevant context included :(
Ok - checking about - I see you are referring to failures at
https://gitlab.com/petsc/petsc/pipelines/91045019
And asserting that master is broken. Ok - to check - I've started a
pipeline on current master at:
https://gitlab.com/petsc/petsc/pipelines/91062141
Satish
On Wed, 23 Oct 2019, Matthew Knepley via petsc-dev wrote:
> I just rebased my branch on master, and now with REPLACE=1 I am getting
> not ok diff-ksp_ksp_tutorials-ex70_fetidp # Error code: 1
> #       1,2d0
> #       <   DMSWARM_PIC: Using method CellDM->LocatePoints
> #       <   DMSWARM_PIC: Using method CellDM->GetNeigbors
> #       mv'ing ex70_fetidp.tmp -->
> /var/folders/hk/tc1pd0g57l78rpt0lttc1sfh0000gn/T/petscdiff.XXXXXX.fjHMBkGr
> I would really liked to get this fixed as fast as possible since it will
> hold up all development.
>   Thanks,
>     Matt
