[petsc-dev] Best Way to Assign Cell Number to VTK Plot in DMPlex
Matthew Knepley
knepley at gmail.com
Fri Oct 4 20:24:23 CDT 2019
On Fri, Oct 4, 2019 at 7:46 PM Faibussowitsch, Jacob <
jfaibussowitsch at anl.gov> wrote:
> If you are requesting a Vec from a Plex, then the discretization in its DS
> determines its size.
> What if I have multiple fields on a single DM with varying numComponents
> per field (although each one has the same quadrature number and dimension I
> believe)? Does it just make the vec based on field 0?
No, the Vec holds everything in the DS.
Matt
> I have made a PetscFE, and used it to set each field, then called
> DMCreateDS on the dm afterwards.
> Best,
> Jacob
> On Oct 4, 2019, at 4:59 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Oct 4, 2019 at 3:09 PM Faibussowitsch, Jacob <
>> Note that Paraview already knows the cell number and can display it
>> Now that would have been useful to know months ago.
>> Here is me making a similar field containing the rank instead of the cell
>> number:
>> Yes I ended up cannibalizing that function and this worked well enough.
>> One thing I noticed however is that it the global vector this creates is of
>> the size of number of cells, but when I create a global vector it is the
>> size of num vertices.
> determines its size. You need to
> make a clone (DMClone) and set a P0 discretization
> This is what I do there.
> Matt
>> I omitted the PETSc__rank_ options prefix part when creating the default
>> fe, is that responsible for setting the vec size here?
>> Best,
>> Jacob
>> On Oct 4, 2019, at 9:42 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Oct 3, 2019 at 11:42 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Oct 1, 2019 at 11:57 AM Faibussowitsch, Jacob via petsc-dev <
>>> petsc-dev at mcs.anl.gov> wrote:
>>>> Hello All,
>>>> I am plotting an output value from a vecview, and want to show in a
>>>> separate plot which cells correspond to which values in the vec. I plan to
>>>> do this by making a field on the cells whose value is the global number of
>>>> that cell. I have 2 issues with this:
>>>> 1. How do I guarantee that the ordering of the Vec I made corresponds
>>>> to the DMPlex cell ordering such that Vec(0) corresponds to Cells(0) etc.
>>>> (I make the Vec separately from the DM since using DMCreateLocalVector
>>>> makes a vector on the vertices)
>>>> 2. I am trying to use DMPlexVTKWriteAll to make my output, so I am
>>>> adding my field to the DMPlexVTK using PetscViewerVTKAddField, but I can’t
>>>> seem to get PetscViewerVTKWriteFunction to work properly, and the man pages
>>>> don’t link to an example. Here is my code for this section:
>>>> PetscErrorCode (*PetscViewerVTKWriteFunction) (PetscObject,
>>>> PetscViewer);
>>>> ierr = PetscViewerCreate(comm=PETSC_COMM_WORLD,
>>>> &vtkviewer);CHKERRQ(ierr);
>>>> ierr = PetscViewerVTKOpen(comm=PETSC_COMM_WORLD, "mesh.vtk",
>>>> FILE_MODE_WRITE, &vtkviewer);CHKERRQ(ierr);
>>>> ierr = PetscViewerSetUp(vtkviewer);CHKERRQ(ierr);
>>>> PetscViewerVTKWriteFunction = (CellNum vtkviewer);
>>>> ierr = PetscViewerVTKAddField(vtkviewer, (PetscObject) dm,
>>>> PetscViewerVTKWriteFunction, PETSC_VTK_CELL_FIELD, PETSC_TRUE,
>>>> CellNum);CHKERRQ(ierr);
>>>> ierr = DMPlexVTKWriteAll((PetscObject) dm, vtkviewer);CHKERRQ(ierr);
>>>> Any help would be greatly appreciated!
>>> I think what you want is to make a Section over cells with 1 dof, fill
>>> it with the cell number (from a global numbering), and then view that Vec.
>> number:
>> https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateRankField.html
>> Thanks,
>> Matt
>>> Matt
>>>> Best,
>>>> Jacob
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191004/e0e67fa4/attachment.html>
