[petsc-dev] Best Way to Assign Cell Number to VTK Plot in DMPlex
    Faibussowitsch, Jacob
    jfaibussowitsch at anl.gov
    Fri Oct  4 18:46:23 CDT 2019
If you are requesting a Vec from a Plex, then the discretization in its DS determines its size.
What if I have multiple fields on a single DM with varying numComponents per field (although each one has the same quadrature number and dimension I believe)? Does it just make the vec based on field 0? I have made a PetscFE,  and used it to set each field, then called DMCreateDS on the dm afterwards.
Best,
Jacob
On Oct 4, 2019, at 4:59 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Oct 4, 2019 at 3:09 PM Faibussowitsch, Jacob <jfaibussowitsch at anl.gov<mailto:jfaibussowitsch at anl.gov>> wrote:
Note that Paraview already knows the cell number and can display it
Now that would have been useful to know months ago.
Here is me making a similar field containing the rank instead of the cell number:
Yes I ended up cannibalizing that function and this worked well enough. One thing I noticed however is that it the global vector this creates is of the size of number of cells, but when I create a global vector it is the size of num vertices.
If you are requesting a Vec from a Plex, then the discretization in its DS determines its size. You need to
  make a clone (DMClone) and set a P0 discretization
This is what I do there.
   Matt
I omitted the PETSc__rank_ options prefix part when creating the default fe, is that responsible for setting the vec size here?
Best,
Jacob
On Oct 4, 2019, at 9:42 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Thu, Oct 3, 2019 at 11:42 AM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, Oct 1, 2019 at 11:57 AM Faibussowitsch, Jacob via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Hello All,
I am plotting an output value from a vecview, and want to show in a separate plot which cells correspond to which values in the vec. I plan to do this by making a field on the cells whose value is the global number of that cell. I have 2 issues with this:
1. How do I guarantee that the ordering of the Vec I made corresponds to the DMPlex cell ordering such that Vec(0) corresponds to Cells(0) etc. (I make the Vec separately from the DM since using DMCreateLocalVector makes a vector on the vertices)
2. I am trying to use DMPlexVTKWriteAll to make my output, so I am adding my field to the DMPlexVTK using PetscViewerVTKAddField, but I can’t seem to get PetscViewerVTKWriteFunction to work properly, and the man pages don’t link to an example. Here is my code for this section:
PetscErrorCode        (*PetscViewerVTKWriteFunction) (PetscObject, PetscViewer);
ierr = PetscViewerCreate(comm=PETSC_COMM_WORLD, &vtkviewer);CHKERRQ(ierr);
ierr = PetscViewerVTKOpen(comm=PETSC_COMM_WORLD, "mesh.vtk", FILE_MODE_WRITE, &vtkviewer);CHKERRQ(ierr);
ierr = PetscViewerSetUp(vtkviewer);CHKERRQ(ierr);
PetscViewerVTKWriteFunction = (CellNum vtkviewer);
ierr = PetscViewerVTKAddField(vtkviewer, (PetscObject) dm, PetscViewerVTKWriteFunction, PETSC_VTK_CELL_FIELD, PETSC_TRUE, CellNum);CHKERRQ(ierr);
ierr = DMPlexVTKWriteAll((PetscObject) dm, vtkviewer);CHKERRQ(ierr);
Any help would be greatly appreciated!
I think what you want is to make a Section over cells with 1 dof, fill it with the cell number (from a global numbering), and then view that Vec.
  https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateRankField.html
     Matt
   Matt
Best,
Jacob
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191004/3668d2af/attachment-0001.html>
