[petsc-dev] Should v->valid_GPU_array be a bitmask?
Zhang, Junchao jczhang at mcs.anl.gov
Tue Oct 1 22:24:27 CDT 2019
Stafano recently modified the following code,
PetscErrorCode VecCreate_SeqCUDA(Vec V)
  PetscErrorCode ierr;
  PetscFunctionBegin;
  ierr = PetscLayoutSetUp(V->map);CHKERRQ(ierr);
  ierr = VecCUDAAllocateCheck(V);CHKERRQ(ierr);
  ierr = VecCreate_SeqCUDA_Private(V,((Vec_CUDA*)V->spptr)->GPUarray_allocated);CHKERRQ(ierr);
  ierr = VecCUDAAllocateCheckHost(V);CHKERRQ(ierr);
  ierr = VecSet(V,0.0);CHKERRQ(ierr);
  ierr = VecSet_Seq(V,0.0);CHKERRQ(ierr);
  V->valid_GPU_array = PETSC_OFFLOAD_BOTH;
  PetscFunctionReturn(0);
That means if one creates an SEQCUDA vector V and then immediately tests if (V->valid_GPU_array == PETSC_OFFLOAD_GPU), the test will fail. That is counterintuitive.  I think we should have
enum {PETSC_OFFLOAD_UNALLOCATED=0x0,PETSC_OFFLOAD_GPU=0x1,PETSC_OFFLOAD_CPU=0x2,PETSC_OFFLOAD_BOTH=0x3}
and then use if (V->valid_GPU_array & PETSC_OFFLOAD_GPU). What do you think?
--Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191002/58bd0e06/attachment.html>
