[petsc-dev] Best Way to Assign Cell Number to VTK Plot in DMPlex
Matthew Knepley
knepley at gmail.com
Fri Oct 4 16:59:42 CDT 2019
On Fri, Oct 4, 2019 at 3:09 PM Faibussowitsch, Jacob <
jfaibussowitsch at anl.gov> wrote:
> Note that Paraview already knows the cell number and can display it
> Now that would have been useful to know months ago.
> Here is me making a similar field containing the rank instead of the cell
> number:
> Yes I ended up cannibalizing that function and this worked well enough.
> One thing I noticed however is that it the global vector this creates is of
> the size of number of cells, but when I create a global vector it is the
> size of num vertices.
If you are requesting a Vec from a Plex, then the discretization in its DS
determines its size. You need to
make a clone (DMClone) and set a P0 discretization
This is what I do there.
Matt
> I omitted the PETSc__rank_ options prefix part when creating the default
> fe, is that responsible for setting the vec size here?
> Best,
> Jacob
> On Oct 4, 2019, at 9:42 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 3, 2019 at 11:42 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Oct 1, 2019 at 11:57 AM Faibussowitsch, Jacob via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>>> Hello All,
>>> I am plotting an output value from a vecview, and want to show in a
>>> separate plot which cells correspond to which values in the vec. I plan to
>>> do this by making a field on the cells whose value is the global number of
>>> that cell. I have 2 issues with this:
>>> 1. How do I guarantee that the ordering of the Vec I made corresponds to
>>> the DMPlex cell ordering such that Vec(0) corresponds to Cells(0) etc. (I
>>> make the Vec separately from the DM since using DMCreateLocalVector makes a
>>> vector on the vertices)
>>> 2. I am trying to use DMPlexVTKWriteAll to make my output, so I am
>>> adding my field to the DMPlexVTK using PetscViewerVTKAddField, but I can’t
>>> seem to get PetscViewerVTKWriteFunction to work properly, and the man pages
>>> don’t link to an example. Here is my code for this section:
>>> PetscErrorCode (*PetscViewerVTKWriteFunction) (PetscObject,
>>> PetscViewer);
>>> ierr = PetscViewerCreate(comm=PETSC_COMM_WORLD,
>>> &vtkviewer);CHKERRQ(ierr);
>>> ierr = PetscViewerVTKOpen(comm=PETSC_COMM_WORLD, "mesh.vtk",
>>> FILE_MODE_WRITE, &vtkviewer);CHKERRQ(ierr);
>>> ierr = PetscViewerSetUp(vtkviewer);CHKERRQ(ierr);
>>> PetscViewerVTKWriteFunction = (CellNum vtkviewer);
>>> ierr = PetscViewerVTKAddField(vtkviewer, (PetscObject) dm,
>>> PetscViewerVTKWriteFunction, PETSC_VTK_CELL_FIELD, PETSC_TRUE,
>>> CellNum);CHKERRQ(ierr);
>>> ierr = DMPlexVTKWriteAll((PetscObject) dm, vtkviewer);CHKERRQ(ierr);
>>> Any help would be greatly appreciated!
>> I think what you want is to make a Section over cells with 1 dof, fill it
>> with the cell number (from a global numbering), and then view that Vec.
> number:
> https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateRankField.html
> Thanks,
> Matt
>> Matt
>>> Best,
>>> Jacob
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191004/44d5c55e/attachment.html>
