[petsc-dev] Fwd: [DL-interest] The missing piece in deep learning?
Smith, Barry F.
bsmith at mcs.anl.gov
Thu May 16 13:16:02 CDT 2019
Looks like that job is now done.
Begin forwarded message:
From: "Foster, Ian T. via DL-interest" <dl-interest at lists.cels.anl.gov<mailto:dl-interest at lists.cels.anl.gov>>
Subject: [DL-interest] The missing piece in deep learning?
Date: May 16, 2019 at 11:52:29 AM CDT
To: "DL-interest at lists.cels.anl.gov<mailto:DL-interest at lists.cels.anl.gov>" <DL-interest at lists.cels.anl.gov<mailto:DL-interest at lists.cels.anl.gov>>
Reply-To: "Foster, Ian T." <foster at anl.gov<mailto:foster at anl.gov>>
Have you ever lamented the lack of good DNN tools in Fortran? If so, you need lament no longer.
https://arxiv.org/pdf/1902.06714
A parallel Fortran framework for neural networks and deep learning
This paper describes neural-fortran, a parallel Fortran frame- work for neural networks and deep learning. It features a simple interface to construct feed-forward neural networks of arbitrary structure and size, several activation functions, and stochastic gradient descent as the default optimization algorithm. neural-fortran also leverages the Fortran 2018 standard collective subroutines to achieve data-based paral- lelism on shared- or distributed-memory machines.
DL-interest mailing list
https://lists.cels.anl.gov/mailman/listinfo/dl-interest
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190516/8ff6b16b/attachment.html>
