[petsc-dev] reading gmsh into DMPlex
Adrian Croucher a.croucher at auckland.ac.nz
Sun May 19 18:40:15 CDT 2019
hi
On 16/05/19 7:37 PM, Stefano Zampini wrote:
> Can you try with this PR
> https://bitbucket.org/petsc/petsc/pull-requests/1660/binary-i-o-and-gmsh-dmplex-reader/diff?
Yes, I just tried using PETSc 3.11.2 which has this PR merged in, and it
does work again now. Thanks!
Cheers, Adrian
>> On May 16, 2019, at 5:59 AM, Adrian Croucher via petsc-dev
>> <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>> hi
>> A couple of years ago (see below) I was having problems reading in
>> GMSH files using DMPlexCreateFromFile(), if the MSH file didn't have
>> a newline on the end.
>> It was fixed at the time, but the problem seems to be happening again
>> with PETSc 3.11.1.
>> I've attached an example mesh which no longer works (unless you add a
>> newline on the end of it). The error message is below.
>> - Adrian
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: File is not a valid Gmsh file, expecting $EndElements
>> [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision:
>> v3.11.1-701-g5065da2f63  GIT Date: 2019-05-13 01:43:35 -0
>> 500
>> [0]PETSC ERROR: ./plexview on a linux-gnu-c-opt named en-354401 by
>> acro018 Thu May 16 14:54:13 2019
>> [0]PETSC ERROR: Configure options --with-x --download-hdf5
>> --download-zlib --download-pnetcdf --download-
>> netcdf --download-exodusii --download-triangle --download-ptscotch
>> --download-chaco --download-hypre --wi
>> th-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
>> CXXOPTFLAGS="-O3 -march=native -mtune=native"
>> FOPTFLAGS="-O3 -march=native -mtune=native"
>> [0]PETSC ERROR: #1 GmshExpect() line 80 in
>> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexgmsh.c
>> [0]PETSC ERROR: #2 GmshReadEndSection() line 108 in
>> lexgmsh.c
>> [0]PETSC ERROR: #3 DMPlexCreateGmsh() line 1107 in
>> exgmsh.c
>> [0]PETSC ERROR: #4 DMPlexCreateGmshFromFile() line 989 in
>> plex/plexgmsh.c
>> [0]PETSC ERROR: #5 DMPlexCreateFromFile() line 3268 in
>> x/plexcreate.c
>> [0]PETSC ERROR: #6 User provided function() line 0 in User file
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190520/af572043/attachment.html>
