[petsc-dev] do PETSC_VIEWER_{HDF5,BINARY}_ need to exist?
    Matthew Knepley
    knepley at gmail.com
    Wed May  8 07:02:07 CDT 2019
On Wed, May 8, 2019 at 7:41 AM Hapla Vaclav via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Hello
> I just encountered their manpages and it's a mess. I think in case of file
> I/O, a user should be deliberate about filename and other settings.
> Sometimes less is more and I think this is the case. Why anybody should use
> PETSC_VIEWER_BINARY_(comm) and then set the filename with environment
> variable? Better to use PetscObjectViewFromOptions for instance
> (PETSC_OPTIONS can be used if one wants to use env var).
> (And BTW in case of HDF5, the option -viewer_hdf5_filename is not
> processed anywhere.)
> Any objections about removing these?
I am fine with it. The new system is better.
Since these are user interface, we should deprecate them somehow. Will the
normal deprecation work?
    Matt
> Vaclav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190508/958ef740/attachment.html>
