[petsc-dev] PETSc Meeting errata
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Fri Jun 14 05:31:19 CDT 2019
I take back one thing I mentioned in my talk in Atlanta. I think I said that Lustre striping does not really influence the read performance. With my latest results in hand, I must point out this is not true. I might have been confused by some former Piz Daint Lustre performance issues and/or HDF5 library issues I mentioned.
Here are my latest slides from PASC19.
https://polybox.ethz.ch/index.php/s/PPZLSyZOKo3UXPS
On slide 18, there is some comparison for different stripe settings. I can now see a speed-up of ~4 for 1 vs 12 stripes (which is actually the number of cores per node) for the mesh with 128M elements. The times are very similar for 8 and 64 computation nodes.
Toby, could you maybe forward this message to the meeting attendees? I don't want to leave anybody confused.
Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190614/f3368172/attachment.html>
