[petsc-dev] [petsc-maint] Dependence of build on test target broken
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Thu Jul 11 20:46:02 CDT 2019
> On Jul 11, 2019, at 6:02 PM, Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Barry,
> Do you want to handle the revert? Satish, do you?
   The problem is the old code doesn't properly handle the dependencies and always produces the error about deleting non-empty directory. I'd like to understand the underlying problem rather then just  go from a new broken thing to an old broken thing.
>   Thanks,
>     Matt
> On Thu, Jul 11, 2019 at 3:02 PM Balay, Satish via petsc-maint <petsc-maint at mcs.anl.gov> wrote:
> BTW: I think this commit also triggers the following error - but I haven't yet debugged this..
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/07/10/examples_master_arch-osx-10.6-cxx-pkgs-opt_ipro.log
> Satish
> > > On Thu, 11 Jul 2019, Matthew Knepley via petsc-dev wrote:
> > > > After my latest pull of master, making the 'test' target no longer rebuilds
> > > > the library. I have tested this on a few arches, and rebuilt. This is
> > > > pretty inconvenient, but I do not know how to fix it.
> > > git bisect gives the following.
> > > Satish
> > > 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224 is the first bad commit
> > > commit 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224
> > > Author: Barry Smith <bsmith at mcs.anl.gov>
> > > Date:   Sat Jun 22 22:56:05 2019 -0500
> > >     Fix the error from gmakefile.test test about trying to remove a non-empty directory
> > >     The problem was the target to rm -r the directory was running at the same time as
> > >     tests tests where generatering new files in the directory
> > >     Commit-type: bug-fix
> > > :100644 100644 67a00e0c1c9ce3eb91a88f314e81a74ac278131f 9c0c1b310a238fc27df3af114ec96336ef5640d2 M      gmakefile.test
> > specifically the following change (with recursive make) likely broke the dependencies..
> > -test: pre-clean report_tests
> > +test:
> > +     +@${OMAKE} -f gmakefile.test pre-clean
> > +     +@${OMAKE} -f gmakefile.test report_tests
> > Satish
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
