[petsc-dev] [petsc-maint] Dependence of build on test target broken
Thu Jul 11 18:02:30 CDT 2019
Barry,
Do you want to handle the revert? Satish, do you?
    Matt
On Thu, Jul 11, 2019 at 3:02 PM Balay, Satish via petsc-maint <
petsc-maint at mcs.anl.gov> wrote:
> BTW: I think this commit also triggers the following error - but I haven't
> yet debugged this..
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/07/10/examples_master_arch-osx-10.6-cxx-pkgs-opt_ipro.log
> Satish
> > > On Thu, 11 Jul 2019, Matthew Knepley via petsc-dev wrote:
> > > > After my latest pull of master, making the 'test' target no longer
> rebuilds
> > > > the library. I have tested this on a few arches, and rebuilt. This is
> > > > pretty inconvenient, but I do not know how to fix it.
> > > git bisect gives the following.
> > > Satish
> > > 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224 is the first bad commit
> > > commit 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224
> > > Author: Barry Smith <bsmith at mcs.anl.gov>
> > > Date:   Sat Jun 22 22:56:05 2019 -0500
> > >     Fix the error from gmakefile.test test about trying to remove a
> non-empty directory
> > >     The problem was the target to rm -r the directory was running at
> the same time as
> > >     tests tests where generatering new files in the directory
> > >     Commit-type: bug-fix
> > > :100644 100644 67a00e0c1c9ce3eb91a88f314e81a74ac278131f
> 9c0c1b310a238fc27df3af114ec96336ef5640d2 M      gmakefile.test
> > specifically the following change (with recursive make) likely broke the
> dependencies..
> > -test: pre-clean report_tests
> > +test:
> > +     +@${OMAKE} -f gmakefile.test pre-clean
> > +     +@${OMAKE} -f gmakefile.test report_tests
> > Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190711/d64d41ab/attachment.html>
