[petsc-dev] [petsc-maint] Dependence of build on test target broken
Matthew Knepley
knepley at gmail.com
Thu Jul 11 21:44:36 CDT 2019
On Thu, Jul 11, 2019 at 8:46 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jul 11, 2019, at 6:02 PM, Matthew Knepley via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > Barry,
> > Do you want to handle the revert? Satish, do you?
> The problem is the old code doesn't properly handle the dependencies
> and always produces the error about deleting non-empty directory. I'd like
> to understand the underlying problem rather then just go from a new broken
> thing to an old broken thing.
Okay, that is reasonable.
Matt
> > Thanks,
> > Matt
> > On Thu, Jul 11, 2019 at 3:02 PM Balay, Satish via petsc-maint <
> petsc-maint at mcs.anl.gov> wrote:
> > BTW: I think this commit also triggers the following error - but I
> haven't yet debugged this..
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/07/10/examples_master_arch-osx-10.6-cxx-pkgs-opt_ipro.log
> > Satish
> > > > On Thu, 11 Jul 2019, Matthew Knepley via petsc-dev wrote:
> > > > > After my latest pull of master, making the 'test' target no longer
> rebuilds
> > > > > the library. I have tested this on a few arches, and rebuilt. This
> is
> > > > > pretty inconvenient, but I do not know how to fix it.
> > > > git bisect gives the following.
> > > > Satish
> > > > 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224 is the first bad commit
> > > > commit 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224
> > > > Author: Barry Smith <bsmith at mcs.anl.gov>
> > > > Date: Sat Jun 22 22:56:05 2019 -0500
> > > > Fix the error from gmakefile.test test about trying to remove a
> non-empty directory
> > > > The problem was the target to rm -r the directory was running at
> the same time as
> > > > tests tests where generatering new files in the directory
> > > > Commit-type: bug-fix
> > > > :100644 100644 67a00e0c1c9ce3eb91a88f314e81a74ac278131f
> 9c0c1b310a238fc27df3af114ec96336ef5640d2 M gmakefile.test
> > > specifically the following change (with recursive make) likely broke
> the dependencies..
> > > -test: pre-clean report_tests
> > > +test:
> > > + +@${OMAKE} -f gmakefile.test pre-clean
> > > + +@${OMAKE} -f gmakefile.test report_tests
> > > Satish
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190711/4e06f4d1/attachment-0001.html>
