[petsc-dev] Dependence of build on test target broken
Balay, Satish
balay at mcs.anl.gov
Thu Jul 11 14:59:58 CDT 2019
BTW: I think this commit also triggers the following error - but I haven't yet debugged this..
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/07/10/examples_master_arch-osx-10.6-cxx-pkgs-opt_ipro.log
Satish
> > On Thu, 11 Jul 2019, Matthew Knepley via petsc-dev wrote:
> > > After my latest pull of master, making the 'test' target no longer rebuilds
> > > the library. I have tested this on a few arches, and rebuilt. This is
> > > pretty inconvenient, but I do not know how to fix it.
> > git bisect gives the following.
> > Satish
> > 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224 is the first bad commit
> > commit 27d73d1f0a5c445a3a02971e31a2a1a02ed6d224
> > Author: Barry Smith <bsmith at mcs.anl.gov>
> > Date: Sat Jun 22 22:56:05 2019 -0500
> > Fix the error from gmakefile.test test about trying to remove a non-empty directory
> > The problem was the target to rm -r the directory was running at the same time as
> > tests tests where generatering new files in the directory
> > Commit-type: bug-fix
> > :100644 100644 67a00e0c1c9ce3eb91a88f314e81a74ac278131f 9c0c1b310a238fc27df3af114ec96336ef5640d2 M gmakefile.test
> specifically the following change (with recursive make) likely broke the dependencies..
> -test: pre-clean report_tests
> +test:
> + +@${OMAKE} -f gmakefile.test pre-clean
> + +@${OMAKE} -f gmakefile.test report_tests
> Satish
