[petsc-dev] Two question about DM API
Lisandro Dalcin
dalcinl at gmail.com
Fri Jul 5 10:20:50 CDT 2019
https://bitbucket.org/petsc/petsc/pull-requests/1850/dm-interface/diff
On Fri, 5 Jul 2019 at 14:29, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On Fri, 5 Jul 2019 at 09:11, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> Lisandro,
>> Both plans look good to me. Remove DMCreateAggregates completely and
>> reactor DMHasCreateInjection.
> Barry, I need a bit of help. What should we do for DMDA?
> 1) Should the code used in DMCreateAggregates_DA be used to implement a
> new DMCreateRestriction_DA (which is not currently implemented), or should
> I just kill DMCreateAggregates_DA ? This approach is dangerous, right now
> any code using DMDA implicitly uses the transpose of interpolation to
> define restriction (because DMCreateRestriction_DA is not available).
> 2) Or maybe rename DMCreateAggregates_DA to a new public
> DMDACreateAggregates() routine, just in case some third party is using it?
> And then add a deprecation for DMCreateAggregates pointing to the
> DMDACreateAggregates().
> I'm inclined to go with option (2), and I'll start working on it. If you
> prefer (1), it is trivial to refactor.
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
Lisandro Dalcin
Research Scientist
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190705/bd4ac7d5/attachment.html>
