[petsc-dev] Two question about DM API
Lisandro Dalcin dalcinl at gmail.com
Fri Jul 5 06:29:24 CDT 2019
On Fri, 5 Jul 2019 at 09:11, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    Lisandro,
>     Both plans look good to me. Remove DMCreateAggregates completely and
> reactor DMHasCreateInjection.
Barry, I need a bit of help. What should we do for DMDA?
1) Should the code used in DMCreateAggregates_DA be used to implement a new
DMCreateRestriction_DA (which is not currently implemented), or should I
just kill DMCreateAggregates_DA ? This approach is dangerous, right now any
code using DMDA implicitly uses the transpose of interpolation to define
restriction (because DMCreateRestriction_DA is not available).
2) Or maybe rename DMCreateAggregates_DA to a new public
DMDACreateAggregates() routine, just in case some third party is using it?
And then add a deprecation for DMCreateAggregates pointing to the
DMDACreateAggregates().
I'm inclined to go with option (2), and I'll start working on it. If you
prefer (1), it is trivial to refactor.
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190705/78580252/attachment.html>
