[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2019-01-11
    Hapla  Vaclav
    vaclav.hapla at erdw.ethz.ch
    Fri Jan 11 10:29:33 CST 2019
Satish, can you please do the same with my haplav/feature-hdf5-improve-attribute-io?
Thanks
Vaclav
> On 11 Jan 2019, at 17:27, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Sorry - meant to say 'next' - not 'master'
> Satish
> On Fri, 11 Jan 2019, Satish Balay wrote:
>> merged latest origin/Fande-Kong/fixed_hierarchical_partitioning_weights_master to master.
>> Satish
>> On Fri, 11 Jan 2019, Fande Kong via petsc-checkbuilds wrote:
>>> Hi Karl,
>>> Could you merge my patch into next? So that we do not receive these
>>> complaints any more.
>>> Thanks,
>>> Fande Kong,
>>> On Fri, Jan 11, 2019 at 6:28 AM PETSc checkBuilds <
>>> petsc-checkbuilds at mcs.anl.gov> wrote:
>>>> Dear PETSc developer,
>>>> This email contains listings of contributions attributed to you by
>>>> `git blame` that caused compiler errors or warnings in PETSc automated
>>>> testing.  Follow the links to see the full log files. Please attempt to fix
>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
>>>> unable
>>>> to resolve the issues.
>>>> Thanks,
>>>>  The PETSc development team
>>>> warnings attributed to commit
>>>> https://bitbucket.org/petsc/petsc/commits/6c04a3c
>>>> Create an API ISCreateSubIS that extracts
>>>>  src/vec/is/is/interface/index.c:216
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-cxx-quad_grind.log
>>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:27:
>>>> warning: 'owner' may be used uninitialized in this function
>>>> [-Wmaybe-uninitialized]
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-misc_el6.log
>>>> /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:216:20:
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-opt_crank.log
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-cxx-pkgs-opt_wii.log
>>>>      /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-IPL64_thrash.log
>>>>      /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-pkgs-opt_wii.log
>>>>      /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-cuda-single_es.log
>>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-gcc-cxx-avx2_knl.log
>>>>      /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
>>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-gcov_cg.log
>>>>  src/vec/is/is/interface/index.c:217
>>>>      /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
>>>> warning: 'lidx' may be used uninitialized in this function
>>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:27:
>>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
>>>>      /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
>>>> /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:217:21:
>>>>      /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
>>>>      /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
>>>> To opt-out from receiving these messages - send a request to
>>>> petsc-dev at mcs.anl.gov.
