[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2019-01-11
Balay, Satish balay at mcs.anl.gov
Fri Jan 11 10:36:39 CST 2019
ok - merged origin/haplav/feature-hdf5-improve-attribute-io to next.
Satish
On Fri, 11 Jan 2019, Hapla  Vaclav wrote:
> Satish, can you please do the same with my haplav/feature-hdf5-improve-attribute-io?
> Thanks
> Vaclav
> > On 11 Jan 2019, at 17:27, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > Sorry - meant to say 'next' - not 'master'
> > Satish
> > On Fri, 11 Jan 2019, Satish Balay wrote:
> >> merged latest origin/Fande-Kong/fixed_hierarchical_partitioning_weights_master to master.
> >> Satish
> >> On Fri, 11 Jan 2019, Fande Kong via petsc-checkbuilds wrote:
> >>> Hi Karl,
> >>> Could you merge my patch into next? So that we do not receive these
> >>> complaints any more.
> >>> Thanks,
> >>> Fande Kong,
> >>> On Fri, Jan 11, 2019 at 6:28 AM PETSc checkBuilds <
> >>> petsc-checkbuilds at mcs.anl.gov> wrote:
> >>>> Dear PETSc developer,
> >>>> This email contains listings of contributions attributed to you by
> >>>> `git blame` that caused compiler errors or warnings in PETSc automated
> >>>> testing.  Follow the links to see the full log files. Please attempt to fix
> >>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> >>>> unable
> >>>> to resolve the issues.
> >>>> Thanks,
> >>>>  The PETSc development team
> >>>> warnings attributed to commit
> >>>> https://bitbucket.org/petsc/petsc/commits/6c04a3c
> >>>> Create an API ISCreateSubIS that extracts
> >>>>  src/vec/is/is/interface/index.c:216
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-cxx-quad_grind.log
> >>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:27:
> >>>> warning: 'owner' may be used uninitialized in this function
> >>>> [-Wmaybe-uninitialized]
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-misc_el6.log
> >>>> /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:216:20:
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-opt_crank.log
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-cxx-pkgs-opt_wii.log
> >>>>      /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-IPL64_thrash.log
> >>>>      /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-pkgs-opt_wii.log
> >>>>      /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-cuda-single_es.log
> >>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-gcc-cxx-avx2_knl.log
> >>>>      /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> >>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-gcov_cg.log
> >>>>  src/vec/is/is/interface/index.c:217
> >>>>      /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> >>>> warning: 'lidx' may be used uninitialized in this function
> >>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:27:
> >>>>      /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> >>>>      /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
> >>>> /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:217:21:
> >>>>      /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> >>>>      /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
> >>>> To opt-out from receiving these messages - send a request to
> >>>> petsc-dev at mcs.anl.gov.
