[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2019-01-11
Balay, Satish
balay at mcs.anl.gov
Fri Jan 11 10:27:01 CST 2019
Sorry - meant to say 'next' - not 'master'
Satish
On Fri, 11 Jan 2019, Satish Balay wrote:
> merged latest origin/Fande-Kong/fixed_hierarchical_partitioning_weights_master to master.
> Satish
> On Fri, 11 Jan 2019, Fande Kong via petsc-checkbuilds wrote:
> > Hi Karl,
> > Could you merge my patch into next? So that we do not receive these
> > complaints any more.
> > Thanks,
> > Fande Kong,
> > On Fri, Jan 11, 2019 at 6:28 AM PETSc checkBuilds <
> > petsc-checkbuilds at mcs.anl.gov> wrote:
> > > Dear PETSc developer,
> > > This email contains listings of contributions attributed to you by
> > > `git blame` that caused compiler errors or warnings in PETSc automated
> > > testing. Follow the links to see the full log files. Please attempt to fix
> > > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> > > unable
> > > to resolve the issues.
> > > Thanks,
> > > The PETSc development team
> > > warnings attributed to commit
> > > https://bitbucket.org/petsc/petsc/commits/6c04a3c
> > > Create an API ISCreateSubIS that extracts
> > > src/vec/is/is/interface/index.c:216
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-cxx-quad_grind.log
> > > /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:27:
> > > warning: 'owner' may be used uninitialized in this function
> > > [-Wmaybe-uninitialized]
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-opt-misc_el6.log
> > > /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:216:20:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-opt_crank.log
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-cxx-pkgs-opt_wii.log
> > > /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-IPL64_thrash.log
> > > /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:216:20:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-freebsd-pkgs-opt_wii.log
> > > /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-cuda-single_es.log
> > > /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-gcc-cxx-avx2_knl.log
> > > /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:216:20:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/01/11/build_next_arch-linux-pkgs-gcov_cg.log
> > > src/vec/is/is/interface/index.c:217
> > > /usr/home/balay/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> > > warning: 'lidx' may be used uninitialized in this function
> > > /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:27:
> > > /sandbox/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> > > /sandbox/petsc/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
> > > /home/sandbox/petsc/petsc.next/src/vec/is/is/interface/index.c:217:21:
> > > /home/petsc/petsc.next-3/src/vec/is/is/interface/index.c:217:21:
> > > /usr/home/balay/petsc.next-2/src/vec/is/is/interface/index.c:217:21:
> > > To opt-out from receiving these messages - send a request to
> > > petsc-dev at mcs.anl.gov.
