[petsc-dev] Regression in Vec assembly
    Stefano Zampini
    stefano.zampini at gmail.com
    Wed Feb 20 08:35:13 CST 2019
Jed,
thanks. It fixed my issue too.
Il giorno mer 20 feb 2019 alle ore 09:33 Lisandro Dalcin <dalcinl at gmail.com>
ha scritto:
> I tested your fix (on top of master) with my original PetIGA reproducer,
> and the issue seems to be fixed.
> On Wed, 20 Feb 2019 at 08:32, Jed Brown <jed at jedbrown.org> wrote:
>> Yuck, bad bug.  I pushed a one-line fix to your branch.  Can you let me
>> know if there are any outstanding issues?  If it solves the problem for
>> you, I'll cherry-pick it to 'maint'.  Thanks.
>> Stefano Zampini <stefano.zampini at gmail.com> writes:
>> > In the link I have sent you, ex29 was modified to invert the order of
>> values set. There’s also a command line that shows the error
>> > mpiexec -n 3 ./ex29 -n 4 -invert -bs 2
>> > I have added the correct output, but if you run with bts you’ll see
>> some of the entries are scrambled up.
>> >> On Feb 20, 2019, at 1:27 AM, Jed Brown <jed at jedbrown.org> wrote:
>> >> Is this what I'm supposed to see?  What should I be looking at?
>> >> $ mpiexec.hydra -n 3 mpich-clang/tests/vec/vec/examples/tests/ex29 -n
>> 126 -info | grep malloc
>> >> [0] VecAssemblyBegin_MPI_BTS(): Stash has 252 entries, uses 2 mallocs.
>> >> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 0 entries, uses 0
>> mallocs.
>> >> [0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
>> >> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 252 entries, uses 2
>> mallocs.
>> 126 -vec_assembly_legacy -info | grep malloc
>> >> [0] VecAssemblyBegin_MPI(): Stash has 252 entries, uses 2 mallocs.
>> >> [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
>> >> [0] VecAssemblyBegin_MPI(): Stash has 0 entries, uses 0 mallocs.
>> >> [0] VecAssemblyBegin_MPI(): Block-Stash has 252 entries, uses 2
>> mallocs.
>> >>> Jed,
>> >>> I’m resurrecting this thread since I believe this bug has not yet
>> been fixed.
>> >>> I have spent a couple of hours today tracking down a bug in my code,
>> that I finally confined to be related with VecSetValuesBlocked.
>> >>> I have pushed an example that shows the problem here
>> https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor
>> >>> Could you please have a look?
>> >>> Thanks,
>> >>> Stefano
>> >>>> On Apr 24, 2016, at 10:52 PM, Jed Brown <jed at jedbrown.org> wrote:
>> >>>> Lisandro Dalcin <dalcinl at gmail.com> writes:
>> >>>>> Do you remember about this regression? My PetIGA tests are still
>> >>>>> failing with petsc/master.
>> >>>> Yes, I have most of a fix in a branch that I'm working to finish.
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190220/9224153a/attachment-0001.html>
