[petsc-dev] Regression in Vec assembly
Lisandro Dalcin
dalcinl at gmail.com
Wed Feb 20 00:32:56 CST 2019
I tested your fix (on top of master) with my original PetIGA reproducer,
and the issue seems to be fixed.
On Wed, 20 Feb 2019 at 08:32, Jed Brown <jed at jedbrown.org> wrote:
> Yuck, bad bug. I pushed a one-line fix to your branch. Can you let me
> know if there are any outstanding issues? If it solves the problem for
> you, I'll cherry-pick it to 'maint'. Thanks.
> Stefano Zampini <stefano.zampini at gmail.com> writes:
> > In the link I have sent you, ex29 was modified to invert the order of
> values set. There’s also a command line that shows the error
> > mpiexec -n 3 ./ex29 -n 4 -invert -bs 2
> > I have added the correct output, but if you run with bts you’ll see some
> of the entries are scrambled up.
> >> On Feb 20, 2019, at 1:27 AM, Jed Brown <jed at jedbrown.org> wrote:
> >> Is this what I'm supposed to see? What should I be looking at?
> >> $ mpiexec.hydra -n 3 mpich-clang/tests/vec/vec/examples/tests/ex29 -n
> 126 -info | grep malloc
> >> [0] VecAssemblyBegin_MPI_BTS(): Stash has 252 entries, uses 2 mallocs.
> >> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 0 entries, uses 0
> mallocs.
> >> [0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
> >> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 252 entries, uses 2
> mallocs.
> 126 -vec_assembly_legacy -info | grep malloc
> >> [0] VecAssemblyBegin_MPI(): Stash has 252 entries, uses 2 mallocs.
> >> [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
> >> [0] VecAssemblyBegin_MPI(): Stash has 0 entries, uses 0 mallocs.
> >> [0] VecAssemblyBegin_MPI(): Block-Stash has 252 entries, uses 2 mallocs.
> >>> Jed,
> >>> I’m resurrecting this thread since I believe this bug has not yet been
> fixed.
> >>> I have spent a couple of hours today tracking down a bug in my code,
> that I finally confined to be related with VecSetValuesBlocked.
> >>> I have pushed an example that shows the problem here
> https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor
> >>> Could you please have a look?
> >>> Thanks,
> >>> Stefano
> >>>> On Apr 24, 2016, at 10:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> >>>> Lisandro Dalcin <dalcinl at gmail.com> writes:
> >>>>> Do you remember about this regression? My PetIGA tests are still
> >>>>> failing with petsc/master.
> >>>> Yes, I have most of a fix in a branch that I'm working to finish.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190220/f35735c0/attachment.html>
