[petsc-dev] Regression in Vec assembly
    Jed Brown
    jed at jedbrown.org
    Wed Feb 20 12:43:32 CST 2019
https://bitbucket.org/petsc/petsc/pull-requests/1389/vecstashsortcompress_private-fix/diff
Stefano Zampini <stefano.zampini at gmail.com> writes:
> Jed,
> thanks. It fixed my issue too.
> Il giorno mer 20 feb 2019 alle ore 09:33 Lisandro Dalcin <dalcinl at gmail.com>
> ha scritto:
>> I tested your fix (on top of master) with my original PetIGA reproducer,
>> and the issue seems to be fixed.
>> On Wed, 20 Feb 2019 at 08:32, Jed Brown <jed at jedbrown.org> wrote:
>>> Yuck, bad bug.  I pushed a one-line fix to your branch.  Can you let me
>>> know if there are any outstanding issues?  If it solves the problem for
>>> you, I'll cherry-pick it to 'maint'.  Thanks.
>>> > In the link I have sent you, ex29 was modified to invert the order of
>>> values set. There’s also a command line that shows the error
>>> > mpiexec -n 3 ./ex29 -n 4 -invert -bs 2
>>> > I have added the correct output, but if you run with bts you’ll see
>>> some of the entries are scrambled up.
>>> >> On Feb 20, 2019, at 1:27 AM, Jed Brown <jed at jedbrown.org> wrote:
>>> >> Is this what I'm supposed to see?  What should I be looking at?
>>> >> $ mpiexec.hydra -n 3 mpich-clang/tests/vec/vec/examples/tests/ex29 -n
>>> 126 -info | grep malloc
>>> >> [0] VecAssemblyBegin_MPI_BTS(): Stash has 252 entries, uses 2 mallocs.
>>> >> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 0 entries, uses 0
>>> mallocs.
>>> >> [0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
>>> >> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 252 entries, uses 2
>>> mallocs.
>>> 126 -vec_assembly_legacy -info | grep malloc
>>> >> [0] VecAssemblyBegin_MPI(): Stash has 252 entries, uses 2 mallocs.
>>> >> [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
>>> >> [0] VecAssemblyBegin_MPI(): Stash has 0 entries, uses 0 mallocs.
>>> >> [0] VecAssemblyBegin_MPI(): Block-Stash has 252 entries, uses 2
>>> mallocs.
>>> >>> Jed,
>>> >>> I’m resurrecting this thread since I believe this bug has not yet
>>> been fixed.
>>> >>> I have spent a couple of hours today tracking down a bug in my code,
>>> that I finally confined to be related with VecSetValuesBlocked.
>>> >>> I have pushed an example that shows the problem here
>>> https://bitbucket.org/petsc/petsc/commits/1cb7fb90b416ce1d4e4767a0d5a2ef5043656d53?at=stefano_zampini/feature-pcbddc-enablelor
>>> >>> Could you please have a look?
>>> >>> Thanks,
>>> >>> Stefano
>>> >>>> On Apr 24, 2016, at 10:52 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> >>>> Lisandro Dalcin <dalcinl at gmail.com> writes:
>>> >>>>> Do you remember about this regression? My PetIGA tests are still
>>> >>>>> failing with petsc/master.
>>> >>>> Yes, I have most of a fix in a branch that I'm working to finish.
>> Lisandro Dalcin
>> Research Scientist
>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
>> 4700 King Abdullah University of Science and Technology
>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>> http://www.kaust.edu.sa
>> Office Phone: +966 12 808-0459
> Stefano
